multicast on 3560X
Krasnoperov
I'v got a 3560X switch
#sh ver
Cisco IOS Software, C3560E Software (C3560E-UNIVERSALK9NPE-M), Version 15.0(2)SE2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Tue 05-Feb-13 12:08 by prod_rel_team
ROM: Bootstrap program is C3560E boot loader
BOOTLDR: C3560E Boot Loader (C3560X-HBOOT-M) Version 12.2(53r)SE2, RELEASE SOFTWARE (fc1)
uptime is 4 days, 5 hours, 53 minutes
System restarted at 06:33:32 MSK Fri Aug 30 2013
System image file is "flash:/c3560e-universalk9npe-mz.150-2.SE2.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: ipbase
License Type: Permanent
Next reload license Level: ipbase
cisco WS-C3560X-48P (PowerPC405) processor (revision K0) with 262144K bytes of memory.
Processor board ID FDO1703H3A9
Last reset from power-on
3 Virtual Ethernet interfaces
1 FastEthernet interface
52 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 4C:4E:35:31:D1:80
Motherboard assembly number     : 73-12557-08
Motherboard serial number       : FDO17040946
Model revision number           : K0
Motherboard revision number     : A0
Model number                    : WS-C3560X-48P-S
Daughterboard assembly number   : 800-32786-02
Daughterboard serial number     : FDO17032XP4
System serial number            : FDO1703H3A9
Top Assembly Part Number        : 800-31328-07
Top Assembly Revision Number    : B0
Version ID                      : V04
CLEI Code Number                : COMJP00ARD
Hardware Board Revision Number  : 0x04
Switch Ports Model              SW Version            SW Image
*    1 54    WS-C3560X-48P      15.0(2)SE2            C3560E-UNIVERSALK9NPE-M
Configuration register is 0xF
When I try to enable pim on interface, there is no commands(ip pim sparse/dance) on inteface level
#sh run | i multi
ip multicast-routing distributed
#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
(config)#int vlan 84
(config-if)#ip pim ?
  passive  Enable PIM passive interface operation
(config-if)#ip pim
Why it happens? Thanks
Peter Paluch
You are currently running the IPBASE license. You need a higher license, e.g. IPSERVICES, to run full multicast routing. Currently, your multilayer switch supports only what is called PIM Stub Routing which is a strongly scaled-down capability of PIM participation, and is suitable only for routed access layer deployments.
Best regards,
Peter
