Multicast on Cisco 886VA VLAN
axoquent-ksa
Hi all,
I'm trying to configure multicast between 2 VLANs on a Cisco 886VA running IOS 15.2 (3) T1 (advanced security).
While I can set the global "ip multicast-routing" I cannot "ip pim sparse-mode" on my interfaces - ip pim is actually unknown and also doesn't appear in the interface's ip subcommand list when using "?".
The feature navigator says pim is supported on my platform and IOS version.
My config looks like this:
interface FastEthernet3
switchport access vlan 103
no ip address
duplex full
speed 100
interface Vlan103
description LAB3$FW_INSIDE$
ip address 192.168.103.254 255.255.255.0
ip helper-address 192.168.102.31
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip virtual-reassembly in
zone-member security Lab-Zone
ip tcp adjust-mss 1400
VLAN interfaces are within the same firewall zone.
What am I missing here?
Shouldn't multicast work on the Cisco 886VA?
Are there any additional requirements concerning the interfaces or additional configuration?
TIA
  Klaus
Reza Sharifi
I think, you need Advanced IP Services license to support PIM
http://tools.cisco.com/ITDIT/CFN/jsp/by-feature-technology.jsp
Reza Sharifi
Thanks for the quick response.
Feature navigator lists both advanced security and advanced ip services when searching for PIM Version 2.
Anyway, I think you're right - advanced IP services are needed.
  Klaus
