3750X Stack Power Limitation With Non-POE Switch
Robert Ho
We have 9 x 3750x switches with 5-nonPOE and 5-POE.
There is a limitation with 4 POE per stack with Stack Power.
Can we combine all 9 to one stack since there are only 4 POE?
Or, is the 4-switch limitation applied regardless if they are mixed with POE and non-POE?
Thank you
7 Replies 7
Robert Ho
Typo - meant:
We have 9 x 3750x switches with 5-nonPOE and 4-POE.
Thank you
You can stack all 9. The 4 stack restriction is for 'stack power' only. Some people create a stack of 8 with 2 'stack power' stacks
If you want all switches to participate in stackpower, then the 4-switch limitation applies regardless if it is POE or nonPOE? Thanks.
You can only have 4 switches per 'power stack'. If you want non-PoE to be in a power stack the same rules apply. Regular 'data' stacks can still be all nine. Looking below you can see there is a 'data' stack of 9 switches and 3 stack power groups.
S
T
A
C
K
|---SW1--Pwr1
|---SW2--Pwr1
|---SW3--Pwr1
|---SW4--Pwr2
|---SW5--Pwr2
|---SW6--Pwr2
|---SW7--Pwr3
|---SW8--Pwr3
|---SW9--Pwr3
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
Because you're using both PoE an non-PoE switches, you might want to take actual power demands and power supplies into careful account for how you might partition the power stacks.
I don't recommend you have a stack of more than 6 3750X switch units in a stack.  Stack up to 6 and NO MORE.
I try and not stack anymore than two, but that's just me.
