Multicast packets - where are they coming from?
greggyd
Hi all - got an odd question as I've reached the limit of my multicast knowledge. I recently setup a new VLAN on our core switch (Cat9300 with routing enabled), which has an inbound ACL applied to it blocking anything except from specific allowed hosts. The ACL is working fine, but I noticed that it immediately started denying some strange multicast packets trying to get to a non-existent IP address.
Packets are coming from 224.0.0.18 and trying to hit a random IP in the VLAN, but nothing is using that IP address. It's not causing any major issues but does give me some cause for concern as its really spammy and could be affecting network performance. It's also filling up my switch logs with denied packets, making it hard to see any actual denied packets.
I was wondering if there was any way to find the source of these multicast packets? I'm not aware of anything on our network that would be sending them, but aside from knowing the IP range, my multicast knowledge is unfortunately extremely limited, as I don't really ever have to work with it.
2 Accepted Solutions
Aaaah, just looking at what VRRP is - I think this might be our Meraki MX's.... our WAN edge use a pair of MX250's configured with a warm spare, which uses VRRP.
That'll be whats generating the traffic. Odd that its hitting a random interface IP though.
Ok thanks for the replies, you have collectively helped me understand multicast better and figured out the issue!
It was definitely the Meraki MX250's sending out these packets from our WAN edge. Looks like a previous attempt was made to build this VLAN and someone setup a VLAN interface for it on the Meraki MX's, which is what was sending out these broadcast packets to this specific VLAN!
Found the offending interface and removed, all solved!
8 Replies 8
greggyd
I may have just answered my own question - it shows the multicast packets on the "show interfaces" command, so "show int | i line | multicast" is giving me some starting points!!
Good job!
Pulkit Mittal
Here, check this guide.
https://www.cisco.com/c/en/us/support/docs/ip/ip-multicast/16450-mcastguide0.html
If you find this useful, Mark this helpful and accept the solution.
Harold Ritter
Hi @greggyd ,
The multicast group 224.0.0.18 is used by VRRP. So it appears that one of your routers is configured for VRRP.
https://www.iana.org/assignments/multicast-addresses/multicast-addresses.xhtml#multicast-addresses-1
Thanks for this Harold. None of my routers are knowingly setup for this, so I'm still struggling to find what is generating this traffic.
Is there any way to trace these back to their source interface?
Hi @greggyd ,
You need to look at the source address for these multicast packets and find out what is the device owning that address. You could then ping that source address, check what is the MAC address assigned to it trace back to the port where that device is connected.
