Cisco Compact Switches scp undefined error Mac
heeb
Hi. I'm having trouble with the compact switches (100 of them!) when I used the copy scp command and kept getting the undefined error message. I'm trying to download the image bin file from my Mac running OX Sonoma.
This is what I got:
SW#copy scp://172.16.99.117 flash:
Source username [xxxxxxxx]? aaaaaaaa
Source filename []? $(Mac Download directory)/c3560cx/c3560cx-12pd-s/c3560cx-universalk9-mz.152-7.E9.bin
Destination filename [c3560cx-universalk9-mz.152-7.E9.bin]?
%Error opening scp://*****@172.16.99.117//Users/thomas.heeb/Downloads/Cisco_IOS-NX/c3560cx/c3560cx-12pd-s/c3560cx-universalk9-mz.152-7.E9.bin (Undefined error)
Knowing that Apple came out with a newer version of SSH and pretty sure this isn't an issue, since I added the RSA key commands in the ssh_config file:
HostkeyAlgorithms +ssh-rsa
PubkeyAcceptedAlgorithms +ssh-rsa
If it can't be fix, how about how do I bring back the tar file using archive command? Will it work? Thanks.
Torbjørn
Can you check if you get any useful info by enabling debug logging with "debug scp all" and retrying the copy?
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
heeb
Is that what you have in mind?
Mar  6 20:37:27.922: %SSH-3-NO_MATCH: No matching kex algorithm found: client diffie-hellman-group-exchange-sha1,diffie-hellman-group14-sha1 server sntrup761x25519-sha512@openssh.com,curve25519-sha256,curve25519-sha256@libssh.org,ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521,diffie-hellman-group-exchange-sha256,diffie-hellman-group16-sha512,diffie-hellman-group18-sha512,diffie-hellman-group14-sha256
heeb
I was using "debug ip scp" command. Is that the same?
RAdamWilliams
When you entered the source filename did you lead it with a slash? The MRL in the error shows two slashes after the IP when there should only be one.
