Multicast PIM Sparse
agapitca19
Level 5
Level 5
Does multicast need a routing protocol to work?
What if some switches along the path are using SVIs for connectivity,will it still work?
Thanks!
Sorry for the misunderstanding. You need layer 3 connectivity between the devices where multicast is deployed. That does not have to be a routing protocol. Static routes are sufficient. There is no relationship between e.g. EIGRP or OSPF and multicast.
Does that clarify your question ?
Georg Pauwen
if SVIs are involved, you need a multicast routing protocol, such as PIM.
Cisco has a pretty comprehensive paper on the subject:
http://www.cisco.com/en/US/tech/tk828/technologies_white_paper09186a0080092942.shtml
I understand that interfaces involved on multicast have to be configured,which in our case sparse mode and the other basic info about multicasting.
what i want to clarify is, if it is a requirement for a routing protocol like eigrp or ospf running on all switches/routers to make PIM works.
No problem and yes that clarified my question.
Thanks!
