Multicast Routing help needed
millerlw
Level 3
Level 3
I have a situation where I need to get multicast video stream out of a system(sys1), through what will hopefully be a Cisco switch in L3 mode(sys2), to another sytem(sys3) so it can capture the multicast stream.  Sys3 cannot be directly connected to sys1 due to security reasons, so it has to go through sys2.  Sys1 is already setup with dynamic routing so it should not need any changes. Sys3 is already setup, although at this point I do not know if it is a router or switch(few details at this point) and sys3 traffic cannot be allowed back to sys1, so it has to be stopped at sys2.
Any help would be apprecaited.
Leonard
millerlw
Level 3
Level 3
Just for clarification, I would only need help with the setup of sys2, which at this point looks like it may be a Cisco 3560 or 3750, but really could be anything.
Assuming a static join will have to be used and would need to configure OSPF.
Thanks again,
Leonard
millerlw
Level 3
Level 3
Preliminary config attached
Leonard
