Multicast trafficis being flooded on igmp snooping enabled switch
edikmkoyan
I have two devices connected to the same switch, S streams video using multicast, H doesn't send join request, but the multicast is being sent to H, actually it is being flooded. Both hosts are in the same vlan.
Distribution-1#show ver | in WS
cisco WS-C2960-24TT-L (PowerPC405) processor (revision E0) with 65536K bytes of memory.
Model number                    : WS-C2960-24TT-L
*    1 26    WS-C2960-24TT-L    15.0(1)SE2            C2960-LANBASEK9-M
5 Replies 5
Hello
You could try using a filter to stop host be from joining the MC group.
ip access-list  standard IGMP
deny 224.0.0.0 0.0.0.255.
permit any
int x/x
ip igmp access-group IGMP
res
Paul
Kind Regards
Paul
this may work, but I need igmp snooping to work as expected.
I have ova 500 ports and assigning this acl to random subset of that interfaces is not the correct way to go.
and one more thing
thfith_1(config-if)#ip igmp ?
  filter      set IGMP filter profile number
  max-groups  set maximum number of IGMP groups that can be joined
  snooping    IGMP snooping configuration
Hello
Maybe I have mis read your requirement - I was on the understanding you are trying to prohibit an host from receiving igmp requests
You state igmp snooping is enabled, if so is it also enabled for a specific vlans?
Could you possible provide a more detail explanation of what you are actually trying to achieve ?
res
Paul
Kind Regards
Paul
I did ip igmp snooping, isn't that enaugh? should I also do Distribution-1(config)#ip igmp snooping vlan 1 ? If so then why?
