multicast vlan
Krasnoperov
Level 4
Level 4
I have a problem, please describe
I have device which sends TV to network, it has ethernet port and multicast ip 239.1.1.1
I connect this device to 2940 cisco catalyst, to port in separate vlan 666
this switch conect through trunk to 3560 catalyst. From this 3560 I can connect to 2940 by IP for management but when I turn on my TV multicast, I lost my connectivity to 2940, ping become horrable
2940:
TV port
interface FastEthernet0/5
switchport access vlan 666
switchport mode access
switchport port-security
switchport port-security maximum 4
switchport port-security violation restrict
switchport port-security mac-address sticky
switchport port-security mac-address sticky 0006.f41f.625d
logging event spanning-tree
storm-control broadcast level 5.00 4.00
storm-control action shutdown
mdix auto
spanning-tree bpduguard enable
2940:
UPlink port to 3560
interface GigabitEthernet0/1
mdix auto
ip dhcp snooping trust
Also on 3560 I have PC which listen this 239.1.1.5
And I dont see any translataions
Please tell me what should I do on 2940, for L3 multicast passing  through L2 vlan 666 between switches
Ton V Engelen
Level 7
Level 7
i can not see the whole config, but you need at least
- multicast routing
- ip pim (sparse /dense/sparse-dense) mode on the l3 interfaces that you want in for your multicast
- possible a rendez vous point, which depends on ip pim
Do you have configured this?
You can check if any client joins with
show ip igmp membership | i
