multicast
mikegrous
Level 3
Level 3
i am trying to configure a multicast network. Is there any program i can use to test out multicast. This is for my CCIE training. Preferrablly a windows program. Something with a server and client.
5 Replies 5
autobot130
This is an easy one. Windows Media Server running some sort of video stream and use Windows Media Player for the client. Whats fun is if you use a camcorder or webcam and stream live material... it gives you a better appreciation for multicast.
I do not have a windows media server at my disposal. Anything that is a free or cheap download?
Hi MIke,
I take it you are looking for something more than the igmp join-group command??
LR
Harold Ritter
Mike,
You can get test tools for Windows platforms from the following link:
http://www.shepfarm.com/multicast/tools.html
right what i am looking for is something to simulate multicast. IE some cliet server program. where i can start a multicast stream and then receive it elsewhere throughout my test multicast network. Wether it be steaming video or auido it doesnt much matter. Just so i can gain some exp with multicast configs.
hritter
I will try your tools tomorrow. They look like they may work. Thank you.
