Multicasting between vlan
kkpc
I need help for configuration cisco catalist 4500x and catalyst 3750 protokol multicast.
swtitch 4500x is set to layer3:
ip multicast-routing
interface vlan 200
ip pim sparse-mode
interface vlan 203
ip pim sparse-mode
ip pim rp-address (ip 4500x)
swtitch 3750:
interface vlan 200
ip pim sparse-mode
interface vlan 203
ip pim sparse-mode
server is vlan 200
camers is vlan 203
Multicating between vlan200 and 203 not routing, why ?
Working multicasting inside vlan but between vlans is not working.
Thanks for help.
23 Replies 23
kkpc
architecture LAN in in attachment
kkpc
I heve a question,
In the case of multicasts on one switch we configure routing-multicast ?,
Do you need on everyone ?
Only igmp on the others ?
Thx,
Jaderson Pessoa
@kkpc Hello
Could you share below configuration:
ON 4500X
show running-config
ON 3750
show running-config
Because in your topology you told to us that just 4500X is configured as L3 device, in this case, you wont neeed a interface vlan 200 and 203 on others switch and wont need "ip pim sparse-mode" under interface on them.
Jaderson Pessoa
*** Rate All Helpful Responses ***
igmp is default enabled on cisco devices.
Jaderson Pessoa
@ Jaderson Pessoa
part configuration
--- for C3850
interface Vlan200
description vlan200
ip address 172.172.211.3 255.255.255.0
ip pim sparse-dense-mode
interface Vlan203
description Vlan203
ip address 172.21.81.3 255.255.255.0
interface Vlan205
description Vlan205
ip address 172.21.85.3 255.255.255.0
ip pim sparse-mode
ip forward-protocol nd
ip pim rp-address 172.21.85.1
no ip http server
no ip http secure-server
---for C4500
vlan 200
name VLAN200
vlan 200
name VLAN203
vlan 205
name VLAN205
interface Vlan200
description Vlan200
ip address 172.172.211.1 255.255.255.0
interface Vlan203
description Vlan203
ip address 172.21.81.1 255.255.255.0
interface Vlan205
description Vlan205
ip address 172.21.85.1 255.255.255.0
ip pim sparse-mode
no ip http server
ok, good. Connection between switch, could you share configuration under interface?
Jaderson Pessoa
Communication between switches is possible over a LAN. I will remove PIM from the other switches tomorrow and see if it works.
@Jaderson Pessoa
Thx for help.
I removed PIM from the other switches and is working.
Nice guy... thank you for your feedback :)
Jaderson Pessoa
