Configuring Layer 3 switch behind cisco ASA 5505
edwardd0017
I have an ASA 5505 connected to a Layer 3 (3750) switch (Inside) .I have created vlan interfaces on the 3750 switch and enabled ip routing on the switch to enable the vlans to communicate with each other.
Vlan Interfaces on the switch:
Vlan 10: 192.168.10.254
Vlan 20: 192.168.20.254
Vlan 30: 192.168.30.254
I want the devices connected to the 3 vlans to be able to pass through the firewall and get out to the internet.
I have connected the ASA to the 3750 by routed interfaces (192.168.1.1) --------- (192.168.1.2) and they are able to ping each other.
I have also put a default route on the 3750 sending all traffic from the switch to the ASA inside interface (192.168.1.1)
9 Replies 9
Apply NAT on ASA and put route for all three Vlan subnets towards 3750's routed interface - 192.168.1.2.
Hi, Thank you for responding. Below is the config that I have, I still couldn't ping the 192.168.20.x or 192.168.30.x from the firewall inside interface.
L3 Switch
vlan 10
name Link to ASA
interface Vlan10
description Link to ASA
ip add 10.10.10.2 255.255.255.0
ip route 0.0.0.0 0.0.0.0 10.10.10.1
interface GigabitEthernetx/x
switchport mode access
switchport access vlan 10
switchport nonegotiate
spanning-tree portfast
no shutdown
ASA
interface vlan 1
description Link to Core
nameif inside
security-level 100
ip add 10.10.10.1 255.255.255.0
route inside 192.168.20.0 255.255.255.0 10.10.10.2
route inside 192.168.30.0 255.255.255.0 10.10.10.2
Hi edwardd0017,
Do all the devices in VLANs 20 and 30 have their default gateways set to 192.168.20.254 and 192.168.30.254, respectively? Can the devices in VLANs 20 and 30 ping each other; i.e. is inter-VLAN routing working?
Also, and as Vivek highlighted, in the original post you say that VLAN10's SVI IP address is 192.168.10.254, then you say in the next paragraph:
"I have connected the ASA to the 3750 by routed interfaces (192.168.1.1) --------- (192.168.1.2) and they are able to ping each other."
And after that in your conflagration, you're configuring the interfaces of the 3750 and the ASA in the 10.10.10.0/24 subnet. So we're not sure which one is the correct one.
Also, (and this is just a technicality) for the connection to be a "routed" interface between the 3750 and the ASA, you need to configure it on the 3750 with the command "no switchport", and then add the IP address directly on the physical port, and not on the SVI. As I mentioned, this is just a technicality in terms of calling the port a "routed" port, however this shouldn't stop your configuration from working, because an SVI should work just as well (theoretically at least).
Furthermore, if you do want the link between the ASA and the 3750 to be a routed interface, then you're better off just applying /30 subnet to the link, and making it a point-to-point link.
Example:
!On the 3750
configure terminal
no switchport
ip address 10.10.10.2 255.255.255.252
no shutdown
exit
end
Other than that, I'm not familiar with the ASA CLI, but is there a reason why you're specifically assigning the IP address 10.10.10.1 on the VLAN 1 interface of the ASA???
Hi john.laham,
To answer your questions, I'm able to ping between Vlan 20 and 30, therefore the inter-VLAN routing is working. The reason why I'm assigning the ip address on the vlan 1 of the ASA because the ASA model that I have does not allow you to set ip to it's physical interface. I have an ASA 5505 with base license, I think I can only have 3 vlans in it and trunking is not available for the base license. My main objective here really is to have my 3750 handle all the routing.
I apologize for the confusion below is the actual config:
L3 Switch
vlan 10
name Link to ASA
interface Vlan10
ip add 192.168.1.2 255.255.255.0
vlan 20
name Servers
interface vlan 20
description Server Vlan
ip add 192.168.20.254 255.255.255.0
vlan 30
name Workstation
interface Vlan 30
ip add 192.168.30.254 255.255.255.0
interface GigabitEthernet1/0/48
no shutdown
ip route 0.0.0.0 0.0.0.0 192.168.1.1
ASA
interface vlan 1
nameif inside
security-level 100
ip add 192.168.1.1 255.255.255.0
route inside 192.168.20.0 255.255.255.0 192.168.1.2
route inside 192.168.30.0 255.255.255.0 192.168.1.1
Dunno if this was a typo, but your route statement for VLAN 30 (subnet 192.168.30.0) on the ASA is pointing to the wrong IP address.
Should be:
route inside 192.168.30.0 255.255.255.0 192.168.1.2
If that doesn't solve the issue, then please provide us with your "show ip route" outputs. Also a traceroute from the ASA to a device on either of the VLANs.
A post in this discussion has been removed due to possible misconduct. Please refer to the CSC terms of use for more details.
on Asa 5505 cli
you need to
go to global config mode
conf t
then
route outside 0.0.0.0 0.0.0.0 ip address of outside interface.
route inside 192.168.10.0 255.255.255.0 10.10.1.1
route inside 192.168.20.0 255.255.255.0  10.10.1.1
you need make some nat rule implementation like
object network NAT
 subnet 192.168.1.0 255.255.255.0
object network NATV-LAN10
 subnet 192.168.10.0 255.255.255.0
object network NATV-LAN20
 subnet 192.168.20.0 255.255.255.0
object network NATV-LAN30
 subnet 192.168.30.0 255.255.255.0
Tell me please. How to give no switchport command on cisco sf-300 switch?
Is that like this?
object network NAT
