Multicasting between vlan
kkpc
I need help for configuration cisco catalist 4500x and catalyst 3750 protokol multicast.
swtitch 4500x is set to layer3:
ip multicast-routing
interface vlan 200
ip pim sparse-mode
interface vlan 203
ip pim sparse-mode
ip pim rp-address (ip 4500x)
swtitch 3750:
interface vlan 200
ip pim sparse-mode
interface vlan 203
ip pim sparse-mode
server is vlan 200
camers is vlan 203
Multicating between vlan200 and 203 not routing, why ?
Working multicasting inside vlan but between vlans is not working.
Thanks for help.
Jaderson Pessoa
@kkpc Hello
Could you share below configuration:
ON 4500X
show running-config
ON 3750
show running-config
Because in your topology you told to us that just 4500X is configured as L3 device, in this case, you wont neeed a interface vlan 200 and 203 on others switch and wont need "ip pim sparse-mode" under interface on them.
Jaderson Pessoa
*** Rate All Helpful Responses ***
23 Replies 23
Sergey Lisitsin
Can you please show output of
show ip route, show ip mroute and show igmp group from both switches.
@Sergey Lisitsin help me ?
balaji.bandi
can you post :
##show ip mroute
#sh ip igmp groups
#sh ip igmp snooping
PIM is also needed to perform multicast routing between Vlans.
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/12-2/54sg/configuration/guide/config/mcastmls.html
BB
VSS1_B1#show ip mroute
IP Multicast Routing Table
Flags: D - Dense, S - Sparse, B - Bidir Group, s - SSM Group, C - Connected,
L - Local, P - Pruned, R - RP-bit set, F - Register flag,
T - SPT-bit set, J - Join SPT, M - MSDP created entry, E - Extranet,
X - Proxy Join Timer Running, A - Candidate for MSDP Advertisement,
U - URD, I - Received Source Specific Host Report,
Z - Multicast Tunnel, z - MDT-data group sender,
Y - Joined MDT-data group, y - Sending to MDT-data group,
G - Received BGP C-Mroute, g - Sent BGP C-Mroute,
N - Received BGP Shared-Tree Prune, n - BGP C-Mroute suppressed,
Q - Received BGP S-A Route, q - Sent BGP S-A Route,
V - RD & Vector, v - Vector, p - PIM Joins on route,
x - VxLAN group
Outgoing interface flags: H - Hardware switched, A - Assert winner, p - PIM Join
Timers: Uptime/Expires
Interface state: Interface, Next-Hop or VCD, State/Mode
(*, 239.168.1.32), 2d12h/00:02:56, RP 172.21.85.1, flags: SP
Incoming interface: Null, RPF nbr 0.0.0.0
Outgoing interface list: Null
(*, 239.168.1.33), 4d06h/00:02:49, RP 172.21.85.1, flags: SP
(*, 239.168.1.34), 1w4d/00:02:58, RP 172.21.85.1, flags: SP
(*, 239.168.1.35), 4d06h/00:02:56, RP 172.21.85.1, flags: SP
(*, 239.168.1.36), 1w4d/00:02:55, RP 172.21.85.1, flags: SP
VSS1_B1#sh ip igmp groups
IGMP Connected Group Membership
Group Address Interface Uptime Expires Last Reporter Group Accounted
239.168.1.32 Vlan203 2d12h 00:02:49 172.20.26.2
239.168.1.33 Vlan203 4d06h 00:02:55 172.20.26.1
239.168.1.34 Vlan200 4d06h 00:02:50 172.20.26.6
239.168.1.35 Vlan200 4d06h 00:02:48 172.20.26.4
239.168.1.36 Vlan200 4d06h 00:02:56 172.20.26.3
239.168.1.37 Vlan200 4d06h 00:02:50 172.20.26.5
239.168.1.38 Vlan200 4d06h 00:02:50 172.20.26.7
239.20.16.1 Vlan200 4d07h 00:02:50 172.20.16.1
239.20.1.16 Vlan200 6d08h 00:02:50 172.20.1.17
239.20.16.3 Vlan200 4d07h 00:02:57 172.20.16.3
239.20.16.2 Vlan200 4d07h 00:02:49 172.20.16.2
239.20.1.5 Vlan200 4d09h 00:02:50 172.20.17.3
239.20.1.6 Vlan200 4d09h 00:02:48 172.20.17.4
239.20.1.1 Vlan200 6d01h 00:02:50 172.20.1.1
VSS1_B1#sh ip igmp snooping
Global IGMP Snooping configuration:
IGMP snooping : Enabled
IGMPv3 snooping : Enabled
Report suppression : Enabled
TCN solicit query : Disabled
TCN flood query count : 2
Last member query interval : 1000
Vlan 200:
IGMPv2 immediate leave : Disabled
Explicit host tracking : Enabled
Multicast router learning mode : pim-dvmrp
CGMP interoperability mode : IGMP_ONLY
Vlan 201:
Vlan 202:
Vlan 203:
Somebody help ?.
How do you diagnose a problem?
Thx
On VSS1_B1 the igmp groups seems to be odd. The last reporter seems to be in different ip ranges, and also 172.20.26 is seeing on both vlan 200 and 203.
You can also see on the mroute that ther is no sender on any of the groups. There are only *.G entryn.
Can you please post the same outputs for the other switch.
/Mikael
SW3_B2#show ip route
Extended Host Mode is enabled
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
a - application route
+ - replicated route, % - next hop override, p - overrides from PfR
Gateway of last resort is not set
172.20.0.0/16 is variably subnetted, 2 subnets, 2 masks
C 172.20.0.0/16 is directly connected, Vlan200
L 172.20.80.3/32 is directly connected, Vlan200
172.21.0.0/16 is variably subnetted, 8 subnets, 2 masks
C 172.21.81.0/24 is directly connected, Vlan203
L 172.21.81.3/32 is directly connected, Vlan203
C 172.21.82.0/24 is directly connected, Vlan201
L 172.21.82.3/32 is directly connected, Vlan201
C 172.21.83.0/24 is directly connected, Vlan202
L 172.21.83.3/32 is directly connected, Vlan202
C 172.21.85.0/24 is directly connected, Vlan205
L 172.21.85.3/32 is directly connected, Vlan205
172.23.0.0/16 is variably subnetted, 2 subnets, 2 masks
C 172.23.0.0/23 is directly connected, Vlan2
L 172.23.0.3/32 is directly connected, Vlan2
SW3_B2#show ip mroute
x - VxLAN group
(*, 239.255.255.250), 1w0d/00:02:28, RP 172.21.85.1, flags: SP
(*, 239.20.100.60), 02:53:37/00:02:42, RP 172.21.85.1, flags: SP
(*, 239.20.2.4), 4d20h/00:02:28, RP 172.21.85.1, flags: SP
(*, 239.20.2.2), 1w0d/00:02:32, RP 172.21.85.1, flags: SP
(*, 239.20.2.14), 1w0d/00:02:28, RP 172.21.85.1, flags: SP
(*, 239.20.2.26), 1w0d/00:02:33, RP 172.21.85.1, flags: SP
(*, 239.20.100.93), 6d06h/00:02:33, RP 172.21.85.1, flags: SP
How can you diagnose the correctness routing multicast ?
By icmp: ping 239.x.x.x source vlan200 ?
ping 239.x.x.x source vlan203 ?
mlund
Level 7
Level 7
One common problem when mcast is not working, is that the sender is sending with ttl=1, thus the stream will be dropped by the router.
/Mikael
@mlund
should I change this in the switch ?
if so how ?
command: ip multicast ttl-threshold 15 ?
you can do by config no ip mutlicast ttl-threshold, by default set to 1
or you can set on interface
interface vlan XXX
 ip pim sparse-dense-mode
 ip multicast ttl-threshold XX  ( XX is Hop)
BB
not ttl:
(config-if)#ip multicast ?
boundary Boundary for administratively scoped multicast addresses
helper-map Broadcast to Multicast map OR Multicast to ip-address map
limit Limit multicast mroute state
No, You should check what the camera is setting. If they are setting ttl=1, then You have to change that setting in the cameras. If they already have ttl setting that is greater than 1, there is some other problem.
/Mikael
In the cameras ttl=10
