Multicasting Help
oneirishpollack
I have been trying to understand the technical steps to setting up multicasting and I am just not getting it. I would appreciate any help I could get.
I have a multicast source (server 10.4.93.10).
I have two multicast receivers (10.4.93.100 and 10.4.94.100).
I enabled multicast on my core router using ip multicast routing
The VLAN is setup as follows:
interface Vlan93
description movies
ip address 10.4.93.1 255.255.255.0
no ip redirects
ip pim sparse-dense-mode
I would like the multicast address to be 239.239.239.239
How do I setup this network for my clients (10.4.93.100 and 10.4.94.100) to join the multicast group (239.239.239.239) so they will be sent the video feed?
Reza Sharifi
under interface vlan93 configure igmp join group
ip igmp join-group 239.239.239.239
Luc De Ghein
I'd guess you have more than one router. If so, please look at some multicast docs on www.cisco.com.
Basically, you'll need to:
-enable multicast routing on the routers
-enable PIM (on the interfaces)
-choose PIM mode:
     PIM sparse mode
     PIM BiDir
     PIM source specific mode  (SSM) (receiver needs to support IGMPv3)
(do not use dense mode, it's getting old )
For the first 2, you'll need a mechanism to have all the PIM routers know which router is the rendez-vous point. For SSM, you'll need to configure an SSM range command.
Do not use the join-group command, unless you'll want the routers to be receivers themselves, which is a bad idea.
Use igmp static-group interface command to have the routers statically forward the multicast group.
Luc
