Multichasis Etherchannel
tahseen12
I am configuring Multichasis LAG between cisco 3750 and Alcatel 7450ESS.Etherchannel is showing up on both sides but no traffic passing through.Also after 15 minutes the interfaces becomes err-disabled on cisco side with message"Channel misconfigured error detected"
I Checked found no misconfiguration.
Any idea has anyone tried this setup???
didyap
Level 6
Level 6
If you are running Native, you can enable the etherchannel misconfig guard by using the below command. This is not enabled by default.
"spanning-tree etherchannel guard misconfig"
For the configuration of Etherchannel follow the link :
http://www.cisco.com/en/US/tech/tk389/tk213/technologies_configuration_example09186a0080094647.shtml
