Multichassis Etherchannel
r.shummoogum
Level 3
Level 3
I have 2 questions.
1. I have 2 Cores(core 1 and Core 2) 6509 connected back to back thru LACP. Can I connect a 6509(distribution) with 2 uplinks, one going to each Core and then activate multichassis Etherchannel. Note: This is a non VSS environement.
2. I have 2 Cisco 6504 with VSS enabled and I have one Nexus 7K with 2 VDC( VDC1 and VDC2)
Can I do multi-chassis etherchannel between the Nexus and the 6504 VSS with one link between VDC1 to the VSS and the other is between VDC2 and the VSS.
Many Thanks
2 Accepted Solutions
Giuseppe Larosa
Hello R.shummoogum
I can answer only to your first question:
without VSS you cannot deploy an etherchannel that spans over multiple standalone C6500 chassis
Hope to help
Giuseppe
tdistlists
Level 3
Level 3
For you second question, the vPC is tied to a specific VDC, so you can only have your etherchannel to your VSS within the same VDC domain.
See this link:
"A vPC domain is associated to a single VDC, so all vPC interfaces belonging to a given vPC domain must be defined in the same VDC"
-source- http://www.cisco.com/en/US/docs/switches/datacenter/sw/4_2/nx-os/interfaces/configuration/guide/if_vPC.html
Hope that helps
Giuseppe Larosa
Hello R.shummoogum
Hope to help
Giuseppe
Thanks for your quick response.
The second one is a rare case and will probably need to be lab'ed.
tdistlists
Level 3
Level 3
See this link:
Hope that helps
Well you just made my day.
Thanks so much.
