PBR troubbleshooting
B@B@r
Level 2
Level 2
Dear all,
 i am trying to learning PBR my topology is mentioned above i am using EIGRP and i have two gateways one is 256k and other is 512K so eigrp choose 512K as high bandwidth.
so now i am tyring to do is that if pc pings to ip 22.22.22.22 it would go through s1/0
but i failed
here is my configuration of R1 for PBR
ip local policy route-map gateway
ip forward-protocol nd
no ip http server
no ip http secure-server
access-list 100 permit ip host 1.1.1.2 host 22.22.22.22
route-map gateway permit 1
match ip address 100
set ip next-hop 10.12.0.2
but my result is still the default route set by eigrp
PC1> trace 22.22.22.22
trace to 22.22.22.22, 8 hops max, press Ctrl+C to stop
1 1.1.1.1 15.626 ms 16.111 ms 21.796 ms
2 10.13.0.2 46.880 ms 53.051 ms 53.038 ms
3 *22.22.22.22 84.309 ms (ICMP type:3, code:3, Destination port .
i need your assistance..
If you want to use PBR you have to apply it somewhere. I see you create the route-map, but I don't see you applying it to the inbound interface. You should apply it to the inbound interface so it knows what to do with the packets it receives.
To apply it, use the following command:
interface Fa0/0
ip policy route-map gateway
The command that you've entered now (ip local policy route-map gateway) is only applicable to data coming from the router itself (that is, coming from the control plane instead of the data plane).
15 Replies 15
B@B@r
Level 2
Level 2
again clear topology
Georg Pauwen
my first thought is: are both routes in your routing table ? Can you post the output of:
show ip route
and
show ip eigrp topology
Thankyou
NO, show ip route just show me one route i.e 10.13.0.2
YES, Show ip eigrp topolog  have the both routes.   ie 10.13.0.2 and 10.12.0.2
you need to get both routes into your routing table. Configure:
variance 2
under your EIGRP process...
why ?
i dont want load-balancing
supposed one route is VIP and 1.1.1.2 is our boss . so if i gonna configure variance so rest of host can access this route....
Hello
variance 2
Hello Georg
PBR isnt required unless the OP want to use PBR, and neither is the Variance feature thats for Equal Cost Load Balancing and as you can see the the prefix is in the topology table, so the rtr is aware of it -
What you can do is manipulate the eigrp distance metric from the least preffered advertsing rtr for that route.
Example:
access-list 10 permit 22.22.22.0 0.0.0.255
router eigrp
distance 91 10.13.0.2 0.0.0.0 10
res
Paul
Kind Regards
Paul
Thankyou for reply
Paul,
i dont want to mess with AD and want to do PBR to change the routing decision.
what do you want to accomplish ? Your PBR takes care of the routing, you can specify who is allowed to take the route or not. But you need the route in the routing table to start out with...
i simply want to accomplish that without changing the Variance and AD , if we ping from  1.1.1.2  the reply should be from the interface serial 1/0 i.e 10.12.0.2. which is not happening there might be a misconfiguration in PBR.
i am learning CCNP . i am doing my labs standalone....
and you know in that case if you stuck then it sucks....
Hello
Apologies Georg this is incorrect - you dont need the route in the route table to PBR in eigrp, The route in the rib is ONLY specifying the BEST route , but all routes learned by the eigrp rtr are in the topology table so PBR can be accomplished.
res
Paul
Kind Regards
Paul
@paul driver wrote:
Hello
res
Paul
You don't even need the route in the EIGRP table; as long as the next hop is reachable, PBR will work. You can even play with the 'default' command to make it only choose a PBR next-hop when a next-hop in the routing table is unavailable.
paul,
yes agreed.......
routing table is just showing you the best route,
but not all the possible route (secondary route) or Backup routes.
Backup routes will be active if your best route failed...
So PFB is applied on all possbile routes that are in toplology tables for specific host or network...
thank you all
interface Fa0/0
yeah it works,
thank-you.
But then in which scenario we use   R(Config)# ip local policy route-map gateway
of-course i understand my mistake that i should be apply it in interface inbound because packet will generate from that interface and PBR take care of it before going to routeing table decision.
but in which case i use it Locally.
