Multiple boot system images on Cisco IES Switches
dierosan1
Guys,
I have some IES (Industrial Ethernet Switches) in the network, and would like to know if is it possible to have two boot system images, one primary and another secondary.
In fact, I can't put the config lines "boot system flash:/image_name.bin" in running/startup-config, but I can see the image in the output of "show boot", as follows (notice that the second image is under a directory with the same name):
router# conf t
router# boot system flash:/ies-lanbasek9-mz.150-2.SE.bin
router# boot system flash:/ies-lanbase-mz.122-52.SE/ies-lanbase-mz.122-52.SE
As we can see bellow, nothing appears on running nor startup-config after command insertion:
router#sh run | i boot
boot-start-marker
boot-end-marker
router#sh startup-config | i boot
boot-start-marker
boot-end-marker
And in the "show boot" output, we can only see the image path that was last configured with "boot system" command. It seems like IOS replaces the image path that was configured first by the one that was last configured:
router#sh boot
BOOT path-list      : flash:/ies-lanbase-mz.122-52.SE/ies-lanbase-mz.122-52.SE
Config file         : flash:/config.text
Wierd stuff in "show version"
router#sh ver | i register
Configuration register is 0xF
Do you guys know if this platform, running this IOS (ies-lanbasek9-mz.150-2.SE.bin), supports multiple boot system images?
Thanks in advance!
10 Replies 10
Leo Laohoo
Yes and no.  Yes, two (or more) complete IOS can be accommodated but this will depend if the appliance(s) themselves have "junk" files in them or not.
However, the appliance can take two (or more) IOS version but the boot variable statement will only accept one.  Unlike the chassis-based system where one can specify two (or more) boot variable statements, I believe this model will only accept one boot variable statement.
I have labbed this, and it's true, this platform only accepts one boot image in the boot var, so it's not possible to manually configure a list with multiple images to be loaded in sequence, in order to have a primary image and a secondary image manually configured.
The same happens to 2950, 2955.
Best Regards.
Hi Leo, One of my clients is using IE4100 switch and configured multiple boot variable images but its only booting from the existing image. Switch can take and show both the images in boot path list with a ; but only boot the existing secondary image and not the first one. This is the boot statement:
TEST#show boot
BOOT path-list : sdflash:/ie4010-universalk9-mz.152-7.E3/ie4010-universalk9-mz.152-7.E3.bin;sdflash:/ie4010-universalk9-mz.152-7.E2/ie4010-universalk9-mz.152-7.E2.bin
but it loads the E2 image. There is no error on the boot and it simply goes to E2:
Loading "sdflash:/ie4010-universalk9-mz.152-7.E2/ie4010-universalk9-mz.152-7.E2.bin"... Verifying image sdflash:/ie4010-universalk9-mz.152-7.E2/ie4010-universalk9-mz.152-7.E2.bin.............................................................................................................................................................................................................................................................................................................................................................................................................................Image passed digital signature verification
I tried searching all over but couldn't see any official documentation, about these switches not supporting multiple images in the boot. Can you please explain your above statement for clarity?
JC
This original thread is about the first generation of IES switches which the IE4010 is not a part/family of.
I do not really agree with multiple boot variable statement for access switches, like the IE4010, but the boot statement means:
  1. After booting, load IOS version 15.2(7)E3 found in the SD Flash.
  2. If 15.2(7)E3 fails, boot 15.2(7)E2 found in the SD Flash.
  3. If 15.2(7)E2 fails, boot whatever supported BIN file is found.
Thanks for your reply, Leo. Thats makes sense.
I have tried setting up the Boot variable with two files but looks like for some reason its still going into "sdflash:/ie4010-universalk9-mz.152-7.E2/ie4010-universalk9-mz.152-7.E2.bin" and loading the E2 image.
This is happening even though I have copied the bin file directly into sdflash: and pointing to it. Looks like switch is not understanding the following boot variable and loading the default E2 file from directory.
I have tried with the following statements
TEST#show boot
BOOT path-list : sdflash:ie4010-universalk9-mz.152-7.E3.bin;ie4010-universalk9-mz.152-7.E2.bin
TEST#show boot
BOOT path-list : sdflash:ie4010-universalk9-mz.152-7.E3.bin;sdflash:ie4010-universalk9-mz.152-7.E2.bin
But still its loading from the directory-
Can you suggest if I am missing anything?
JC
Never "copied the bin file directly into sdflash:" because it is archaic and chances are high to get the boot-variable statement wrong.
Use the recommended method:
archive download-sw tftp://<TFTP_IP_ADDRESSS>/filename.tar sdflash:
The method above will automatically change the boot-variable correctly.
Agree Leo,
I can ask customer to delete the bin files and try archive download method for the E3. Will they be able to use two boot images in the boot path after that? The switch is able to boot automatically on E3 if its is the only image in the boot variable.
Customer wants two images, primary E3 and secondary E2 as this is a remote site and they don't want any manual intervention if in case first one doesn't load.
JC
Uhhhhh ... That is dumb.  And what if someone runs away with the SD flash or the SD flash fails?
If I want to do a two-boot-variable, I'd put E3 as a primary boot variable and the on-board flash as the secondary image.
You mean something like this-
BOOT path-list : sdflash:ie4010-universalk9-mz.152-7.E3.bin;flash:ie4010-universalk9-mz.152-7.E2.bin ?
Another important thing to point is - They tried making flash E3 image into the boot variable like this - BOOT path-list : flash:ie4010-universalk9-mz.152-7.E3.bin
But it still loaded the sdflash: E2 file even though the sdflash wasn't listed in the boot variable. When they check the boot path-list, it came as empty after reload like below:
TEST#conf t
Enter configuration commands, one per line. End with CNTL/Z.
XXX_TEST(config)#boot system flash:ie4010-universalk9-mz.152-7.E3.bin
WARNING: The BOOT/config file path points to the
On-board flash. The environment variable(s) is
saved onto the On-board flash.
NOTE: This warning message is displayed only once.
XXX_TEST(config)#do wr
Building configuration...
[OK]
XXX_TEST(config)#^Z
XXX_TEST#show boot
Config file : sdflash:/config.text
Private Config file : flash:/private-config.text
Enable Break : yes
Manual Boot : no
Allow Dev Key : yes
HELPER path-list :
Auto upgrade : yes
Auto upgrade path :
Boot optimization : enabled
NVRAM/Config file
buffer size: 524288
Timeout for Config
Download: 0 seconds
Config Download
via DHCP: disabled (next boot: disabled)
XXX_TEST#
XXX_TEST#
XXX_TEST#relo
XXX_TEST#reload
Proceed with reload? [confirm]
CPU rev: B
Board rev: 5
Testing DataBus...
Testing AddressBus...
Using driver version 4 for media type 1
Xmodem file system is available.
Base ethernet MAC Address: 68:87:c6:64:a4:00
The password-recovery mechanism is enabled.
USB Console INIT
Initializing Flash...
mifs[5]: 12 files, 1 directories
mifs[5]: Total bytes : 1806336
mifs[5]: Bytes used : 834560
mifs[5]: Bytes available : 971776
mifs[5]: mifs fsck took 1 seconds.
mifs[6]: 1 files, 1 directories
mifs[6]: Total bytes : 3870720
mifs[6]: Bytes used : 133632
mifs[6]: Bytes available : 3737088
mifs[6]: mifs fsck took 0 seconds.
mifs[7]: 5 files, 1 directories
mifs[7]: Total bytes : 258048
mifs[7]: Bytes used : 8192
mifs[7]: Bytes available : 249856
mifs[7]: mifs fsck took 0 seconds.
mifs[8]: 5 files, 1 directories
mifs[8]: Total bytes : 258048
mifs[8]: Bytes used : 8192
mifs[8]: Bytes available : 249856
mifs[8]: mifs fsck took 0 seconds.
mifs[9]: 1819 files, 109 directories
mifs[9]: Total bytes : 122185728
mifs[9]: Bytes used : 98243584
mifs[9]: Bytes available : 23942144
mifs[9]: mifs fsck took 2 seconds.
...done Initializing Flash.
File "sdflash:/ie4010-universalk9-mz.152-7.E2/ie4010-universalk9-mz.152-7.E2.bin" uncompressed and installed, entry point: 0x3000
executing...
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, IE4010 Software (IE4010-UNIVERSALK9-M), Version 15.2(7)E2, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2020 by Cisco Systems, Inc.
Compiled Sun 15-Mar-20 07:57 by prod_rel_team
Initializing flashfs...
mifs[7]: 12 files, 1 directories
mifs[7]: Total bytes : 1806336
mifs[7]: Bytes used : 834560
mifs[7]: Bytes available : 971776
mifs[7]: mifs fsck took 1 seconds.
mifs[7]: Initialization complete.
mifs[8]: 1 files, 1 directories
mifs[8]: Total bytes : 3870720
mifs[8]: Bytes used : 133632
mifs[8]: Bytes available : 3737088
mifs[8]: Initialization complete.
mifs[9]: 5 files, 1 directories
mifs[9]: Total bytes : 258048
mifs[9]: Bytes used : 8192
mifs[9]: Bytes available : 249856
mifs[9]: mifs fsck took 0 seconds.
mifs[9]: Initialization complete.
mifs[10]: 5 files, 1 directories
mifs[10]: Total bytes : 258048
mifs[10]: Bytes used : 8192
mifs[10]: Bytes available : 249856
mifs[10]: mifs fsck took 0 seconds.
mifs[10]: Initialization complete.
mifs[11]: 1819 files, 109 directories
mifs[11]: Total bytes : 122185728
mifs[11]: Bytes used : 98243584
mifs[11]: Bytes available : 23942144
mifs[11]: mifs fsck took 1 seconds.
mifs[11]: Initialization complete.
...done Initializing flashfs.
Checking for Bootloader upgrade..
Boot Loader upgrade not needed(v)
FIPS: Flash Key Check : Begin
FIPS: Flash Key Check : End, Not Found, FIPS Mode Not Enabled
POST: MA BIST : End, Status Skipped
FPGA Initialization done!
POST: ACT2 Authentication : Begin
Platform-SCC:SUDI-H authentication passed: 0x0 - TAM_RC_OK
POST: ACT2 Authentication : End, Status Passed
Downloading FPGA image ...... done
POST: Inline Power Controller Tests : Begin
POST: Inline Power Controller Tests : End, Status Skipped
POST: PortASIC Port Loopback Tests : Begin
POST: PortASIC Port Loopback Tests : End, Status Skipped
Waiting for Port download...Complete
Initializing Port Extension Feature Support...
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco IE-4010-4S24P (APM86XXX) processor (revision W0) with 1048576K bytes of memory.
Processor board ID FDO2602J0GP
Last reset from power-on
1 Virtual Ethernet interface
28 Gigabit Ethernet interfaces
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 68:87:C6:64:A4:00
Motherboard assembly number : 73-101622-03
Motherboard serial number : FDO2553109J
Model revision number : W0
Motherboard revision number : E0
Model number : IE-4010-4S24P
System serial number : FDO2602J0GP
Top Assembly Part Number : 68-6047-01
Top Assembly Revision Number : R0
Version ID : V01
Hardware Board Revision Number : 0x05
Backplane FPGA version : 1.26
CIP Serial Number : 0x0864A400
SKU Brand Name : Cisco
Device Manager Package : Multi-language
Switch Ports Model SW Version SW Image
* 1 28 IE-4010-4S24P 15.2(7)E2 IE4010-UNIVERSALK9-M
SD Flash Manufacturer : SMART MODULAR (ID=89h)
Serial number : 10195D0C
Error: Could not initialize specific sgacl tcam entries
Press RETURN to get started!
C
Master : XXX KBWT30185
C
User Access Verification
Username:
%Error deleting sdflash:ssh.enable (No such file or directory)mmgadmin
Password: C
Mmg limited - MMGNET / ACCESS SWITCH - Rosebery (AUS)- AU1004 - KBWT30185
XXX_TEST#
XXX_TEST#
XXX_TEST#show boot
BOOT path-list :
Enable Break : yes
Manual Boot : no
Allow Dev Key : yes
HELPER path-list :
Auto upgrade : yes
Auto upgrade path :
NVRAM/Config file
buffer size: 524288
Timeout for Config
Download: 0 seconds
Config Download
XXX_TEST#
JC
