Multiple VLANs on the Same Port on Cisco Catalyst 3508G XL Aggregation Switch
On my old Catalyst 2508G-XL, I am trying to achive this:
Ports 1-2 -> Port Group 1, Trunked with a newer HP Switch
Ports 3-4 -> Port Group 2, Trunked with a newer HP Switch
Port 6-7-8 -> Port Group 3, Trunked with pfSense Router (Load Balanced LAGG, VLAN 1 - VLAN 2)
This is my configuration:
3508G-XL#show running-config
Building configuration...
Current configuration:
version 12.0
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname 3508G-XL
enable secret 5 ***************************************
ip subnet-zero
ip name-server 192.168.0.1
interface GigabitEthernet0/1
 port group 1 distribution destination
 switchport mode trunk
 no cdp enable
interface GigabitEthernet0/2
 no cdp enable
interface GigabitEthernet0/3
 port group 2 distribution destination
 no cdp enable
interface GigabitEthernet0/4
 no cdp enable
interface GigabitEthernet0/5
 switchport trunk allowed vlan 1,2,1002-1005
 no cdp enable
interface GigabitEthernet0/6
 port group 3 distribution destination
 no cdp enable
interface GigabitEthernet0/7
 no cdp enable
interface GigabitEthernet0/8
 no cdp enable
interface VLAN1
 ip address 192.168.0.3 255.255.252.0
 no ip directed-broadcast
 no ip route-cache
ip default-gateway 192.168.0.1
no cdp run
snmp-server engineID local 000000090200000AF4E6AC80
snmp-server community private RW
snmp-server community public RO
line con 0
 transport input none
 stopbits 1
 speed 115200
line vty 0 4
 login
line vty 5 15
 login
end
Here is my problem:
I have an old Lenovo T400 laptop. Its Intel 82567LM Ethernet card supports VLAN tagging. And there are two VLANs defined: VLAN 1, VLAN 2.
VLAN 1 address -> 192.168.0.2/22
VLAN 2 address -> 10.0.0.2/8
I want to connect this laptop to Port 5 on the switch. I want both VLANs to work on the same port so that I can use this laptop for multiple purposes.
How should I configure Port 5 so that the Lenovo T400 can communicate on both VLANs?
"This new learning amazes me, Sir Bedevere. Explain again how sheep's bladders may be employed to prevent earthquakes." King Arthur
After a lot of trial&error, I finally got it to work!
It seems putting the port in access mode will not do the trick. What needs to be done is to put it in trunk mode:
 port group 4 distribution destination
 no cdp enable
This is identical to the configuration of the other ports exccept for the port group number.
I also had to configure the laptop's Intel card:
VLAN_MAIN -> Untagged
VLAN_INFO -> ID 2
Now it works like a charm.
Hi there,
Since you do not have a port-channel to your laptop you can lose the port group command. Also you should specifify the VLANs you want to trunk to the laptop. The switchport should look like this:
  no cdp enable
cheers,
seb.
Thank you very. I'll give that a try and keep you informed.
But what do you mean by "your laptop you can lose the port group command"? What can go wrong with the current configuration?
That worked too. But this time, when I tried to ping my laptop's DHCP-assingned IP, I got this:
# ping -S 192.168.0.1 192.168.0.109
PING 192.168.0.109 (192.168.0.109) from 192.168.0.1: 56 data bytes
64 bytes from 192.168.0.109: icmp_seq=0 ttl=128 time=0.298 ms
64 bytes from 192.168.0.109: icmp_seq=0 ttl=255 time=1.100 ms (DUP!)
64 bytes from 192.168.0.109: icmp_seq=1 ttl=128 time=0.191 ms
64 bytes from 192.168.0.109: icmp_seq=1 ttl=255 time=1.037 ms (DUP!)
64 bytes from 192.168.0.109: icmp_seq=2 ttl=128 time=0.200 ms
64 bytes from 192.168.0.109: icmp_seq=2 ttl=255 time=1.059 ms (DUP!)
64 bytes from 192.168.0.109: icmp_seq=3 ttl=128 time=0.198 ms
64 bytes from 192.168.0.109: icmp_seq=3 ttl=255 time=1.042 ms (DUP!)
64 bytes from 192.168.0.109: icmp_seq=4 ttl=128 time=0.233 ms
64 bytes from 192.168.0.109: icmp_seq=4 ttl=255 time=1.065 ms (DUP!)
64 bytes from 192.168.0.109: icmp_seq=5 ttl=128 time=0.206 ms
64 bytes from 192.168.0.109: icmp_seq=5 ttl=255 time=1.033 ms (DUP!)
^C
That did not happen with the previous configuration.
And it does not happen with the other DHCP-assigned IP:
# ping -S 10.0.0.1 10.0.0.4
PING 10.0.0.4 (10.0.0.4) from 10.0.0.1: 56 data bytes
64 bytes from 10.0.0.4: icmp_seq=0 ttl=128 time=0.235 ms
64 bytes from 10.0.0.4: icmp_seq=1 ttl=128 time=0.244 ms
64 bytes from 10.0.0.4: icmp_seq=2 ttl=128 time=0.244 ms
64 bytes from 10.0.0.4: icmp_seq=3 ttl=128 time=0.225 ms
64 bytes from 10.0.0.4: icmp_seq=4 ttl=128 time=0.235 ms
64 bytes from 10.0.0.4: icmp_seq=5 ttl=128 time=0.252 ms
64 bytes from 10.0.0.4: icmp_seq=6 ttl=128 time=0.249 ms
What is happening?
