OSPF on 3650
jeeshu.singla
Can anyone please confirm if i can run OSPF on 3650 for around 600 ospf routes with ipbase license.
If it can, then what is the minimum firmware version required.
Jeeshu
GRANT3779
This may help -
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3650/software/release/3se/routing/configuration_guide/b_rt_3se_3650_cg/b_rt_3se_3650_cg_chapter_011.html#ID1849
"OSPF for Routed Access supports only one OSPFv2 and one OSPFv3 instance with a maximum number of 200 dynamically learned routes."
IP Base only supports for OSPF for routed access. IP Services provides complete Layer 3 services.
