MVRP
gary.minnis
Community Member
I am putting several catalyst 3650's and 2960's in an environment that is mostly HP switches.  The HP switches use GVRP for vlan pruning.  I thought I could use MVRP on the cisco switches but I can't find the command.  VTP is not an option, I need something that is 'cross platform'.  Does anyone have any ideas?
Anthony LaRosa
Level 2
Level 2
Gary,
MVRP for Cisco was on the CAT6000 series for IOS and the 7000 series for NX-OS.
You will need to manually propagate the VLANs between HP and Cisco and verify that the STP protocol you select is compatible with HP.
Also, make sure that the interconnecting links between HP and Cisco are 802.1q trunks. ISL tagging is proprietary as well.
Anthony
