My 6500 router always start in romoon
emil.eriksson
I have a problem that have been an issu for a very long time and I cant get it solve.
So I hope there is anyone here that can help me.
When my router restarts, power failure, when I type "reload" or other things who make it reboot itself. It always stop in "rommon>" and Its very annoying.
This Is how my config is:
6500-FK01#show boot
BOOT variable = disk0:s72033-advipservicesk9_wan-mz.122-33.SXI5.bin,1;disk0:,12;sup-bootflash:,12
CONFIG_FILE variable =
BOOTLDR variable = bootflash:s72033-boot-mz.122-33.SXI3.bin
Standby is not up.
6500-FK01#dir disk0:
Directory of disk0:/
    1  -rw-   116737380   Jan 1 2000 03:17:08 +01:00  s72033-advipservicesk9_wan-mz.122-33.SXI5.bin
127918080 bytes total (11177984 bytes free)
How can I make my router to boot up automaticly?
Many thanks! Emil
6 Replies 6
Leo Laohoo
Your boot variable string is incorrect.
To correct this, you need to do this:
config t
no [ENTER INCORRECT BOOT VARIABLE STRING HERE]
boot system flash disk0:s72033-advipservicesk9_wan-mz.122-33.SXI5.bin
end
wr
Thanks for the tip!
Now Its looks like this!
show run
hostname 6500-FK01
enable password 7 065043355E4F11
show boot
6500-FK01#show boot
Standby is not up.
I cant test this right away because this router are in production right now.
Is this correct? :)
Many thanks.
That should be correct, Emil.
Thank you Leo Laohoo! =)
This will be intressting that day we need to reboot again.
Iulian Vaideanu
Level 4
Level 4
What does "remote command switch show version | include register" output?
Naveen Venkateshaiah
check for "remote command switch show version"
and look for config register value to be 0x2102------>if it is different change it to 0x2102
r1>conf t
r1-conf> config-register 0x2102
r1>write mem
and than reload
Naveen
****rate if it is helpful****
