My cisco 1841 router can't start
Lova RABAKO
Hi every one.
I have a problem on a 1841 cisco router. It says :
System Bootstrap, Version 12.4(13r)T8, RELEASE SOFTWARE (fc1)
Copyright (c) 2008 by cisco Systems, Inc.
PLD version 0x10
GIO ASIC version 0x127
c1841 platform with 262144 Kbytes of main memory
Main memory is configured to 64 bit mode with parity disabled
Upgrade ROMMON initialized
program load complete, entry point: 0x8000f000, size: 0xcb80
program load complete, entry point: 0x8000f000, size: 0x2051924
Error : compressed image checksum is incorrect 0x51C9E7C5
        Expected a checksum of 0x2975AF66
*** System received a Software forced crash ***
signal= 0x17, code= 0x5, context= 0x80014e00
PC = 0x8000f0d4, Cause = 0x20, Status Reg = 0x3041e803
PLD version 0x10
Error : compressed image checksum is incorrect 0xC243E88F
PLD version 0x10
Error : compressed image checksum is incorrect 0x6508E488
PLD version 0x10
Error : compressed image checksum is incorrect 0x8BB2E539
PLD version 0x10
Entering rommon> prompt after several failed attempts to boot an IOS image.
Please check your internal/external flash drives for the correct IOS image
and issue 'reset' at the rommon> prompt to re-try the boot process.
rommon 1 >
I boot it on usbflash that contain a 1841 ios. but it always returns the error above.
Please help ...
Leo Laohoo
The IOS is corrupt.
Where did you get this ROMmon version?  I've never seen this before and it's not in the Cisco Download Centre.
Check if you have got other IOS file on your flash drive,
ROMMON> dir flash:
If so try to boot your router from the other file
boot flash:/file2.bin
If not you have to copy a new IOS image with tftp from ROMMON.
Network Group
