Bookmark
Subscribe
946
My QOS class-map is not matching
harisivaji
I have configured class-map which matches based on access-group
this accessgroup is configured to match one specific host
i created a policymap and add this classmap under this and i specified "drop" action (Just for testing; assuming all the traffic thro the host wll be dropped-Is is correct ???)
Add the service policy command in WAN interface in Input direction (so the download will be affected)
when i verified access-list is matched but not the class-map
Where iam wrong
Any suggestions
Jerry Ye
Can you post the configuration and a short description of traffic direction.
jerry
Class-map match-any dropall
match accessgroup MYPC
policy-map MYPOLICY
class dropall    /*earlier i specified same bandwidth value /
drop
Int fa0/1     /*my WAN interface*/
serive policy input MYPOLICY
Ip access-list extended MYPC
10 permit host 10.29.10.10 any
This i did to make sure that QOS which i configured is working fine or not
becuase iam not able to verify (Frankly saying i dont know ) it
Just i want to limit the download speed of this particular pc when he is accessing WAN so i applied in input direction in WAN
In lan interface there is nothing .related to this
Hari
Your ACL is wrong, you are matching the traffic in the wrong direction.
Assuming you mean download from the Internet
Internet -> F0/1 Router -> PC (10.29.10.10)
the ACL should be like the follow
ip access-list extended MYPC
permit ip any host 10.29.10.10
HTH,
jerry
My Network is Like this
Internet====[router]====Switch===PC
Yes you are right i will check and
reply  tomorrow
Thanks for your time
Hari
