N3k 3132 QSFP+ port in linkFlapErrDisabled state
nathalye
We have a Nexus 3132 switch with 32x40G supervisor module. I connected Port 9 with a breakout cable ( breaking out into 4 10G links on the other end of it) to UCS rack server with Cisco VIC card 1225 10G interface. The port is initially came up and then shortly moved to linkFlapErrDisabled.
Eth1/9/1      1       eth  trunk  down    linkFlapErrDisabled         10G(D) --
Did some more digging but still no clue why it moves to this state. Here is the interface config:
interface Ethernet1/9/1
  speed 10000
  description link to L3 out host orion2-esx9
  switchport mode trunk
  switchport trunk allowed vlan 300,400
  no shutdown
The remaining 3 ports 1/9/2, 1/9/3 and 1/9/4 are not connected anywhere. Err-disabled status shows:
orion2-n3k1# show interface status err-disabled
Port         Name               Status   Reason
Eth1/9/1     link to L3 out hos linkFlap linkFlapErrDisabled
orion2-n3k1#
I tried shut/no shut on this interface but doesnt help. Any ideas why the port is flapping?
Here is the hardware information from 'show run' output:
hardware profile portmode 32x40G
hardware profile front portmode qsfp
Any help is appreciated
nathalye
'term mon' shows the following:
orion2-n3k1# terminal monitor
2015 Dec  2 14:29:29 orion2-n3k1 %ETHPORT-5-SPEED: Interface Ethernet1/9/1, operational speed changed to 10 Gbps
2015 Dec  2 14:29:29 orion2-n3k1 %ETHPORT-5-IF_DUPLEX: Interface Ethernet1/9/1, operational duplex mode changed to Full
2015 Dec  2 14:29:29 orion2-n3k1 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet1/9/1, operational Receive Flow Control state changed to off
orion2-n3k1# 2015 Dec  2 14:29:29 orion2-n3k1 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet1/9/1, operational Transmit Flow Control state changed to off
2015 Dec  2 14:29:29 orion2-n3k1 %ETHPORT-5-IF_UP: Interface Ethernet1/9/1 is up in mode trunk
2015 Dec  2 14:29:30 orion2-n3k1 %ETHPORT-5-IF_DOWN_LINK_FAILURE: Interface Ethernet1/9/1 is down (Link failure)
2015 Dec  2 14:29:31 orion2-n3k1 last message repeated 1 time
2015 Dec  2 14:29:31 orion2-n3k1 %ETHPORT-5-SPEED: Interface Ethernet1/9/1, operational speed changed to 10 Gbps
2015 Dec  2 14:29:31 orion2-n3k1 %ETHPORT-5-IF_DUPLEX: Interface Ethernet1/9/1, operational duplex mode changed to Full
2015 Dec  2 14:29:31 orion2-n3k1 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet1/9/1, operational Receive Flow Control state changed to off
2015 Dec  2 14:29:31 orion2-n3k1 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet1/9/1, operational Transmit Flow Control state changed to off
2015 Dec  2 14:29:31 orion2-n3k1 %ETHPORT-5-IF_UP: Interface Ethernet1/9/1 is up in mode trunk
2015 Dec  2 14:29:32 orion2-n3k1 %ETHPORT-5-IF_DOWN_LINK_FAILURE: Interface Ethernet1/9/1 is down (Link failure)
2015 Dec  2 14:29:33 orion2-n3k1 last message repeated 1 time
2015 Dec  2 14:29:33 orion2-n3k1 %ETHPORT-5-SPEED: Interface Ethernet1/9/1, operational speed changed to 10 Gbps
2015 Dec  2 14:29:33 orion2-n3k1 %ETHPORT-5-IF_DUPLEX: Interface Ethernet1/9/1, operational duplex mode changed to Full
2015 Dec  2 14:29:33 orion2-n3k1 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet1/9/1, operational Receive Flow Control state changed to off
2015 Dec  2 14:29:33 orion2-n3k1 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet1/9/1, operational Transmit Flow Control state changed to off
2015 Dec  2 14:29:33 orion2-n3k1 %ETHPORT-5-IF_UP: Interface Ethernet1/9/1 is up in mode trunk
2015 Dec  2 14:29:34 orion2-n3k1 %ETHPORT-5-IF_DOWN_LINK_FAILURE: Interface Ethernet1/9/1 is down (Link failure)
2015 Dec  2 14:29:35 orion2-n3k1 last message repeated 1 time
2015 Dec  2 14:29:35 orion2-n3k1 %ETHPORT-5-SPEED: Interface Ethernet1/9/1, operational speed changed to 10 Gbps
2015 Dec  2 14:29:35 orion2-n3k1 %ETHPORT-5-IF_DUPLEX: Interface Ethernet1/9/1, operational duplex mode changed to Full
2015 Dec  2 14:29:35 orion2-n3k1 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet1/9/1, operational Receive Flow Control state changed to off
2015 Dec  2 14:29:35 orion2-n3k1 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet1/9/1, operational Transmit Flow Control state changed to off
2015 Dec  2 14:29:35 orion2-n3k1 %ETHPORT-5-IF_UP: Interface Ethernet1/9/1 is up in mode trunk
2015 Dec  2 14:29:36 orion2-n3k1 %ETHPORT-5-IF_DOWN_LINK_FAILURE: Interface Ethernet1/9/1 is down (Link failure)
2015 Dec  2 14:29:36 orion2-n3k1 last message repeated 1 time
2015 Dec  2 14:29:36 orion2-n3k1 %ETHPORT-5-IF_DOWN_ERROR_DISABLED: Interface Ethernet1/9/1 is down (Error disabled. Reason:Too many link flaps)
Not sure why operational Tx and Rx Flow Control is turned off and there is link failure.
