How many VLANs can I span in a monitor session on a Nexus 7K?
aducey01
rsbd7k01-p-vdca(config)# monitor session 2
rsbd7k01-p-vdca(config-monitor)# source vlan ?
  <1-3967>
rsbd7k01-p-vdca(config-monitor)# source vlan 1 - 3967
ERROR: vlan 33-3967: Number of source vlans exceeds maximum
Thanks dude that was quick!  You ROCK!!!
You are so lucky.  I happened to have the Web page in front of me open and I was reading it today.
Thanks for the rating
Thank you Reza, it helped me a bunch. I was unable to find it using the regular means.
The link is still accurate but the table got shifted. The needed information is in Table 17:
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/sw/verified_scalability/b_Cisco_Nexus_7000_Series_NX-OS_Verified_Scalability_Guide.html#concept_2CDBB777A06146FA934560D7CDA37525
