N5K L2 Multicast
chanseeyee
  1. We have two hosts that within the same subnet i.e one physical server & one VM that need to run on multica
  2. physical server (10.1.1.1/24) is connecting to switch FEX (131/1/18) port . The FEX is dual home design
  3. VM (10.1.1.11/24) that resided in Blade server (ESXi host) is connecting to the switch trunk port E1/18
  4. Both physical and VM are joining multicast group ip: 238.238.18.18
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus5500/sw/layer2/6x/b_5500_Layer2_Config_6x/b_5500_Layer2_Config_602N12_chapter_01100.html
Ive prepare configuration template as attached. Hope to receive some comment on this. Thanks
Yashas Bhadoria
Hello could you please verify that is there any issues you are facing?
