Routing Table Issue
Manjunath MR
As i can see in my forwarding table both default and ospf routes are there. is it normal behavior??
But no static or default routes are used in this switch. physical connection is as below.
source----------Switch_1-------Switch_2---------destination(10.7.0.0)
SWITCH-1#show ip forwarding route vrf media 10.7.0.12
IPv4 Routing Table:
Headers: Dest: Destination, Gw: Gateway, Pri: Priority;
Codes : BROADC: Broadcast, USER-I: User-ipaddr, USER-S: User-special,
MULTIC: Multicast, USER-N: User-network, DHCP-D: DHCP-DFT,
ASBR-V: ASBR-VPN, STAT-V: Static-VRF, DHCP-S: DHCP-static,
GW-FWD: PS-BUSI, NAT64: Stateless-NAT64, LDP-A: LDP-area,
GW-UE: PS-USER, P-VRF: Per-VRF-label, TE: RSVP-TE;
Status codes: *valid, >best;
Dest Gw Interface Owner Pri Metric
*> 10.7.0.12/30 10.47.101.58 vlan2024 OSPF 110 6
*> 10.7.0.12/30 10.47.101.66 vlan2027 OSPF 110 6
*> 10.7.0.12/30 10.47.101.50 vlan2021 OSPF 110 6
*> 10.7.0.12/30 10.47.101.102 vlan2029 OSPF 110 6
*> 0.0.0.0/0 10.47.101.58 vlan2024 OSPF 110 3
*> 0.0.0.0/0 10.47.101.66 vlan2027 OSPF 110 3
*> 0.0.0.0/0 10.47.101.50 vlan2021 OSPF 110 3
*> 0.0.0.0/0 10.47.101.102 vlan2029 OSPF 110 3
SWITCH-1#
SWITCH-1#
There should be a default route configured. Can you post the switch config?
Yashas Bhadoria
Hello ,
Could you please paste the output for #sh ip ospf data
also here theTroubleshooting VRF Configurations
http://www.cisco.com/c/en/us/support/docs/multiprotocol-label-switching-mpls/mpls/13734-mpls-vpn-tsh.html#tshootvrf
SWITCH-1#show ip ospf database process 220
OSPF Router with ID (10.46.255.54) (Process ID 220)
Router Link States (Area 0.0.0.0)
Link State ID ADV Router Age Seq# Checksum Link count
10.2.96.125 10.2.96.125 1239 0x800032d2 0xbee4 6
10.2.96.126 10.2.96.126 617 0x80002c89 0xa48d 5
10.12.18.1 10.12.18.1 1386 0x800013d6 0xd23a 39
Net Link States (Area 0.0.0.0)
10.2.96.1 218.248.72.64 1457 0x800013ce 0xbb30
10.2.96.5 218.248.72.64 1457 0x800013ce 0x8563
10.2.96.9 218.248.72.64 1457 0x800013ce 0x6b78
10.2.96.13 218.248.72.64 1457 0x800013ce 0x35ab
10.2.96.18 10.42.173.104 1243 0x800013cc 0x2af7
10.2.96.22 10.42.173.103 1187 0x800013cc 0xfd22
10.2.96.26 10.42.173.104 1243 0x800013cc 0xd940
10.2.96.30 10.42.173.103 1187 0x800013cc 0xad6a
10.2.96.66 10.2.96.126 1352 0x80001af8 0x7b7
Type-5 AS External Link States
Link State ID ADV Router Age Seq# Checksum Tag
10.47.67.168 10.2.96.126 1093 0x8000000c 0x88ff 0
10.7.0.12 10.42.61.33 437 0x80000017 0x7ed9 3489726432
10.7.0.60 10.42.61.33 478 0x80000017 0x9296 3489726432
10.7.0.84 10.42.61.33 53 0x80001d23 0x1ecb 3489726432
10.7.0.108 10.42.61.33 93 0x80000f19 0x5794 3489726432
10.7.0.132 10.42.61.33 399 0x80000018 0xbd22 3489726432
10.7.2.128 10.42.61.33 439 0x80000017 0xe5fa 3489726432
10.7.2.132 10.42.61.33 439 0x80000017 0xbd1f 3489726432
10.7.2.136 10.42.61.33 439 0x80000017 0x8b4e 3489726432
10.7.2.140 10.42.61.33 55 0x80001d23 0xdfce 3489726432
10.7.2.144 10.42.61.33 55 0x80001d23 0xadfd 3489726432
10.7.2.148 10.42.61.33 55 0x80001d22 0x9b0b 3489726432
10.7.2.247 10.42.61.33 442 0x80000017 0x4d19 3489726432
10.7.2.248 10.42.61.33 442 0x80000017 0x4d17 3489726432
10.7.2.249 10.42.61.33 442 0x80000017 0x2f36 3489726432
10.7.2.250 10.42.61.33 442 0x80000017 0x2f34 3489726432
10.7.2.251 10.42.61.33 55 0x80001d23 0xa199 3489726432
10.7.2.252 10.42.61.33 55 0x80001d22 0x8fac 3489726432
10.7.2.253 10.42.61.33 401 0x80001d08 0xcd85 3489726432
10.7.2.254 10.42.61.33 55 0x80001d23 0x6fca 3489726432
10.7.204.160 10.42.61.33 437 0x80000017 0x7a6d 3489726432
10.7.204.164 10.42.61.33 437 0x80000017 0x5291 3489726432
10.7.204.168 10.42.61.33 437 0x80000017 0x12d1 3489726432
10.7.205.160 10.42.61.33 473 0x80001d08 0x36a2 3489726432
10.7.205.164 10.42.61.33 473 0x80001d08 0xec6 3489726432
10.7.205.168 10.42.61.33 473 0x80001d08 0xcd07 3489726432
10.31.237.56 10.42.61.33 1038 0x800031d8 0x2117 3489726432
10.42.0.8 10.42.61.33 1032 0x80000c84 0xcff4 3489726432
10.7.0.12 10.42.173.237 430 0x80000017 0x9e7c 3489726432
10.7.0.60 10.42.173.237 470 0x80000017 0xb239 3489726432
10.7.0.84 10.42.173.237 470 0x80001d1f 0x466a 3489726432
10.7.0.108 10.42.173.237 470 0x80000f13 0x8331 3489726432
10.7.0.132 10.42.173.237 394 0x80000018 0xddc4 3489726432
10.7.2.128 10.42.173.237 432 0x80000017 0x69d 3489726432
10.7.2.132 10.42.173.237 432 0x80000017 0xddc1 3489726432
10.7.2.136 10.42.173.237 433 0x80000017 0xabf0 3489726432
10.7.2.140 10.42.173.237 471 0x80001d1f 0x86d 3489726432
10.7.2.144 10.42.173.237 471 0x80001d20 0xd39d 3489726432
10.7.2.148 10.42.173.237 471 0x80001d1d 0xc5a8 3489726432
10.7.2.247 10.42.173.237 433 0x80000017 0x6dbb 3489726432
10.7.2.248 10.42.173.237 433 0x80000017 0x6db9 3489726432
10.7.2.249 10.42.173.237 433 0x80000017 0x4fd8 3489726432
10.7.2.250 10.42.173.237 433 0x80000017 0x4fd6 3489726432
10.7.2.251 10.42.173.237 471 0x80001d1c 0xcf35 3489726432
10.7.2.252 10.42.173.237 471 0x80001d1c 0xbb49 3489726432
10.7.2.253 10.42.173.237 471 0x80001d07 0xef27 3489726432
10.7.2.254 10.42.173.237 471 0x80001d1f 0x9769 3489726432
10.7.204.160 10.42.173.237 431 0x80000017 0x9a10 3489726432
10.7.204.164 10.42.173.237 431 0x80000017 0x7234 3489726432
10.7.204.168 10.42.173.237 431 0x80000017 0x3274 3489726432
10.7.205.160 10.42.173.237 467 0x80001d07 0x5844 3489726432
10.7.205.164 10.42.173.237 467 0x80001d07 0x3068 3489726432
10.7.205.168 10.42.173.237 467 0x80001d07 0xefa8 3489726432
10.31.237.56 10.42.173.237 496 0x80001677 0x5522 3489726432
10.42.0.8 10.42.173.237 488 0x80000c89 0xe59c 3489726432
SWITCH-1#
