N5K upgrade -
S891
Level 2
Level 2
HI,
I am planning to do upgrade Nexus switches from 5.2.1.N1.2 to the new NX-OS code. I am wondering what are the options for direct upgrade to new code with zero down time. I have dual N5K with N2Ks with redundant PVCs. Is there possibility for absoloutely zero downtime upgrade on a major release.
5 Replies 5
Robert Falconer
Here are the guidelines:
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus5000/sw/upgrade/503_N1_1/n5k_upgrade_downgrade_503.html#wp640721
ISSU is supported unless you're running L3 on the 5Ks.
I checked for the ISSU upgrade document and the image it recommended was 7.0.3.N1. I downloaded the images on switch and did impact check. There still seems to be some issues with STP and possibly VPC due to which it says the upgrade will be disruptive. Any suggestions on how to avoid/fix this and still do the ISSU upgrade?
N5K-1# show install all impact kickstart bootflash:n5000-uk9-kickstart.7.0.3.N1.1.bin system bootflash:n5000-uk9.7.0.3.N1.1.bin
Verifying image bootflash:/n5000-uk9-kickstart.7.0.3.N1.1.bin for boot variable "kickstart".
[####################] 100% -- SUCCESS
Verifying image bootflash:/n5000-uk9.7.0.3.N1.1.bin for boot variable "system".
Verifying image type.
Extracting "system" version from image bootflash:/n5000-uk9.7.0.3.N1.1.bin.
Extracting "kickstart" version from image bootflash:/n5000-uk9-kickstart.7.0.3.N1.1.bin.
Extracting "bios" version from image bootflash:/n5000-uk9.7.0.3.N1.1.bin.
Extracting "fexth" version from image bootflash:/n5000-uk9.7.0.3.N1.1.bin.
Performing module support checks.
Notifying services about system upgrade.
Compatibility check is done:
Module  bootable          Impact  Install-type  Reason
     1       yes      disruptive         reset  STP ISSU preupgrade check failed - Upgrade needs to be disruptive!
   101       yes      disruptive         reset  STP ISSU preupgrade check failed - Upgrade needs to be disruptive!
   102       yes      disruptive         reset  STP ISSU preupgrade check failed - Upgrade needs to be disruptive!
   111       yes      disruptive         reset  STP ISSU preupgrade check failed - Upgrade needs to be disruptive!
   112       yes      disruptive         reset  STP ISSU preupgrade check failed - Upgrade needs to be disruptive!
Images will be upgraded according to following table:
Module       Image         Running-Version             New-Version  Upg-Required
     1      system             5.2(1)N1(2)             7.0(3)N1(1)           yes
     1   kickstart             5.2(1)N1(2)             7.0(3)N1(1)           yes
     1        bios      v3.6.0(05/09/2012)      v3.6.0(05/09/2012)            no
     1      SFP-uC                v1.0.0.0                v1.0.0.0            no
   101       fexth             5.2(1)N1(2)             7.0(3)N1(1)           yes
   102       fexth             5.2(1)N1(2)             7.0(3)N1(1)           yes
   111       fexth             5.2(1)N1(2)             7.0(3)N1(1)           yes
   112       fexth             5.2(1)N1(2)             7.0(3)N1(1)           yes
     1   power-seq                    v5.0                    v7.0           yes
     1          uC                v1.0.0.2                v1.0.0.2            no
Additional info for this installation:
Remove QoS & ACL config on L3 interfaces and SVIs if any
Service "stp" : Port: port-channel10 in VLAN0001 is Designated. Topology change could occur during ISSU.
Upgrade needs to be disruptive!!!
Service "vpc" : STP Preupgrade Check failed on VPC peer switch
ISSU will reset the control plane so spanning tree will be affected.
Do you have any downstream switches that are using the 5Ks as the root for those vlans?
Yes, it has root for vlan 1 which actually is Native vlan for FI trunk. Unfortunately we let it use the default. The other thing is it seems that we have to upgrade power-sequencer images when we go to 7.x.
So when the switches reset the control plane, there will be a spanning tree topology change. This may or may not disrupt traffic in your network.
