N7K interface output discard
alioune-ndiaye
Level 2
Level 2
Hello Guys
Do you have any ideas regarding N7K interface output discard?
here are   some outputs:
N7K1#  sh int eth7/3
Ethernet7/3 is up
  Dedicated Interface
  Hardware: 10000 Ethernet, address: 44d3.ca31.727a (bia 44d3.ca31.727a)
  Description: "SDL36 - SR31 NC2-NX2-BFN"
  MTU 7300 bytes, BW 10000000 Kbit, DLY 10 usec
  Encapsulation ARPA
  Port mode is trunk
  full-duplex, 10 Gb/s, media type is 10G
  Beacon is turned off
  Auto-Negotiation is turned off
  Input flow-control is off, output flow-control is off
  Rate mode is dedicated
  Switchport monitor is off
  EtherType is 0x8100
  Last link flapped 2week(s) 1day(s)
  30 seconds input rate 1581904 bits/sec, 1329 packets/sec
  30 seconds output rate 4846240 bits/sec, 1552 packets/sec
  Load-Interval #2: 5 minute (300 seconds)
    input rate 1.66 Mbps, 1.37 Kpps; output rate 7.23 Mbps, 1.72 Kpps
  RX
    1771847594 unicast packets  23100138 multicast packets  415847 broadcast packets
    1795363579 input packets  772377242887 bytes
    326875 jumbo packets  0 storm suppression packets
    0 runts  0 giants  0 CRC  0 no buffer
    279643 input error  279643 short frame  0 overrun   0 underrun  0 ignored
    0 watchdog  0 bad etype drop  0 bad proto drop  0 if down drop
    0 input with dribble  0 input discard
    0 Rx pause
  TX
    4150213675 unicast packets  7001449 multicast packets  558210 broadcast packets
    4157773334 output packets  1930599703860 bytes
    272590 jumbo packets
    0 output error  0 collision  0 deferred  0 late collision
    0 lost carrier  0 no carrier  0 babble  24539961 output discard
    0 Tx pause
  6 interface resets
N7K1#
N7K2# sh int eth4/2
Ethernet4/2 is up
  Dedicated Interface
  Hardware: 10000 Ethernet, address: 2894.0ffc.3571 (bia 2894.0ffc.3571)
  Description:
  Encapsulation ARPA
  Port mode is trunk
  EtherType is 0x8100
  30 seconds input rate 10165816 bits/sec, 2067 packets/sec
  30 seconds output rate 1754928 bits/sec, 1571 packets/sec
    input rate 6.95 Mbps, 1.78 Kpps; output rate 1.78 Mbps, 1.46 Kpps
  RX
    4145928896 unicast packets  11134106 multicast packets  558547 broadcast packets
    4157621713 input packets  1930741170380 bytes
    269282 jumbo packets  0 storm suppression packets
    0 runts  0 giants  1 CRC  0 no buffer
    16588418 input error  16588417 short frame  0 overrun   0 underrun  0 ignored
    0 Rx pause
  TX
    1771780548 unicast packets  23010768 multicast packets  416317 broadcast packets
    1795207633 output packets  772319216499 bytes
    323684 jumbo packets
    0 lost carrier  0 no carrier  0 babble  43527 output discard
    0 Tx pause
  2 interface resets
version 5.2(1)
interface Ethernet7/3
  description
  switchport
  switchport mode trunk
  switchport trunk allowed vlan 555,598,644,700
  mtu 7300
  no shutdown
N7K1#
version 5.2(1)
interface Ethernet4/2
  description
  switchport
  mtu 7300
  no shutdown
N7K2#
Thank you
Alioune
tobiasdreyer
Same problem here. I'm also wondering about some output discards on interfaces connected to some N5Ks and some firewalls. There is no policy-binding on these interfaces and the utilization is max. 70Mbit/s on a 10Gig/s interface.
Some interfaces have the same count of errors although they are connected to different devices.
Has anyone an explanation for this?
Eth1/18               0          0          0          0          0     4177708
Eth1/20               0          0          0          0          0     4177708
Eth1/22               0          0          0          0          0     4177708
Eth1/24               0          0          0          0          0     4177708
Eth1/25               0          0          0          0          0      112427
Eth1/26               0          0          0          0          0    50815310
Eth1/27               0          0          0          0          0      112427
Eth1/28               0          0          0          0          0    50815310
Eth1/29               0          0          0          0          0      112427
Eth1/30               0          0          0          0          0    50815311
Eth1/31               0          0          0          0          0      112427
Eth1/32               0          0          0          0          0    50815311
Eth2/1                0          0          0          0          0           0
Eth2/2                0          0          0          0          0           0
Eth2/3                0          0          0          0          0           0
Eth2/4                0          0          0          0          0           0
Eth2/5                0          0          0          0          0           0
Eth2/6                0          0          0          0          0           0
Eth2/7                0          0          0          0          0           0
Eth2/8                0          0          0          0          0           0
Eth2/10               0          0          0          0          0           0
Eth2/12               0          0          0          0          0           0
Eth2/14               0          0          0          0          0           0
Eth2/16               0          0          0          0          0           0
Eth2/18               0          0          0          0          0     4246082
Eth2/20               0          1          0          1          0     4246082
Eth2/22               0          0          0          0          0     4246082
Eth2/24               0          0          0          0          0     4246082
Eth2/25               0          0          0          0          0     2930664
Eth2/26               0          0          0          0          0     5592939
Eth2/27               0          0          0          0          0     2930664
Eth2/28               0          0          0          0          0     5592939
Eth2/29               0          0          0          0          0     2930664
Eth2/30               0          0          0          0          0     5592939
Eth2/31               0          0          0          0          0     2930664
Eth2/32               0          0          0          0          0     5592939
Thank you
Tobias
mahmoodmkl
Level 11
Level 11
there lot of input errors on the interface
i suggest change the port n sfp n monitor this link
thank you for your reply. But the input errors are not the errors we are wondering about. But you are right, Alioune should check the SFP/cable.
Any ideas regarding to the output discards?
