10-18-2013 01:31 AM - edited 03-07-2019 04:06 PM
Hi, In a Nexus 7000 after upgrading from 4.1(5) to 5.2.3(a), we have a N7K-M148GT-11 module in powered-dn.
I'm not sure if it is a HW problem, or software.
Any help, thanks
NEXUS_Qro_MAN02# sh logging last 15
2013 Oct 18 00:55:49 NEXUS_Qro_MAN02 %PLATFORM-5-MOD_STATUS: Module 8 current-status is MOD_STATUS_POWERED_UP
2013 Oct 18 01:00:42 NEXUS_Qro_MAN02 %PLATFORM-2-PFM_MODULE_RESET: Manual restart of Module 8 from Command Line Interface
2013 Oct 18 01:00:44 NEXUS_Qro_MAN02 %PLATFORM-2-MOD_DETECT: Module 8 detected (Serial number JAF1333AEEP) Module-Type 10/100/1000 M
bps Ethernet Module Model N7K-M148GT-11
2013 Oct 18 01:00:44 NEXUS_Qro_MAN02 %PLATFORM-2-MOD_PWRUP: Module 8 powered up (Serial number JAF1333AEEP)
2013 Oct 18 01:00:44 NEXUS_Qro_MAN02 %PLATFORM-5-MOD_STATUS: Module 8 current-status is MOD_STATUS_POWERED_UP
2013 Oct 18 01:01:40 NEXUS_Qro_MAN02 %MODULE-5-LCM_MODULE_UPGRADE_START: Upgrade of module 8 started
2013 Oct 18 01:01:40 NEXUS_Qro_MAN02 %MODULE-5-LCM_MODULE_UPGRADE_END: Upgrade of module 8 ended
2013 Oct 18 01:05:52 NEXUS_Qro_MAN02 %PLATFORM-2-MOD_DETECT: Module 8 detected (Serial number JAF1333AEEP) Module-Type 10/100/1000 M
2013 Oct 18 01:05:52 NEXUS_Qro_MAN02 %PLATFORM-2-MOD_PWRUP: Module 8 powered up (Serial number JAF1333AEEP)
2013 Oct 18 01:05:52 NEXUS_Qro_MAN02 %PLATFORM-5-MOD_STATUS: Module 8 current-status is MOD_STATUS_POWERED_UP
2013 Oct 18 01:10:56 NEXUS_Qro_MAN02 %MODULE-2-MOD_FAIL: Initialization of module 8 (serial: JAF1333AEEP) failed
2013 Oct 18 01:10:57 NEXUS_Qro_MAN02 last message repeated 1 time
2013 Oct 18 01:10:57 NEXUS_Qro_MAN02 %PLATFORM-2-MOD_PWRDN: Module 8 powered down (Serial number JAF1333AEEP)
2013 Oct 18 01:10:57 NEXUS_Qro_MAN02 %PLATFORM-5-MOD_STATUS: Module 8 current-status is MOD_STATUS_CONFIGPOWERED_DOWN
2013 Oct 18 01:10:57 NEXUS_Qro_MAN02 %PLATFORM-5-MOD_STATUS: Module 8 current-status is MOD_STATUS_POWERED_DOWN
NEXUS_Qro_MAN02#
NEXUS_Qro_MAN02#
NEXUS_Qro_MAN02#
NEXUS_Qro_MAN02# ^C
NEXUS_Qro_MAN02# ^C
NEXUS_Qro_MAN02#
NEXUS_Qro_MAN02# show environment power
Power Supply:
Voltage: 50 Volts
Power Actual Total
Supply Model Output Capacity Status
(Watts ) (Watts )
1 N7K-AC-6.0KW 798 W 6000 W Ok
2 N7K-AC-6.0KW 802 W 6000 W Ok
3 N7K-AC-6.0KW 777 W 6000 W Ok
Actual Power
Module Model Draw Allocated Status
(Watts ) (Watts )
1 N7K-M148GS-11 278 W 400 W Powered-Up
2 N7K-M148GS-11 286 W 400 W Powered-Up
3 N7K-M132XP-12 N/A 750 W Powered-Up
4 N7K-M132XP-12 N/A 750 W Powered-Up
5 N7K-SUP1 N/A 210 W Powered-Up
6 N7K-SUP1 N/A 210 W Powered-Up
7 N7K-M148GT-11 N/A 400 W Powered-Up
8 N7K-M148GT-11 N/A 0 W Powered-Dn
Xb1 N7K-C7010-FAB-1 N/A 60 W Powered-Up
Xb2 N7K-C7010-FAB-1 N/A 60 W Powered-Up
Xb3 N7K-C7010-FAB-1 N/A 60 W Powered-Up
Xb4 xbar N/A 60 W Absent
Xb5 xbar N/A 60 W Absent
fan1 N7K-C7010-FAN-S 88 W 720 W Powered-Up
fan2 N7K-C7010-FAN-S 88 W 720 W Powered-Up
fan3 N7K-C7010-FAN-F 9 W 120 W Powered-Up
fan4 N7K-C7010-FAN-F 9 W 120 W Powered-Up
N/A - Per module power not available
Power Usage Summary:
Power Supply redundancy mode (configured) PS-Redundant
Power Supply redundancy mode (operational) PS-Redundant
Total Power Capacity (based on configured mode) 12000 W
Total Power of all Inputs (cumulative) 18000 W
Total Power Output (actual draw) 2377 W
Total Power Allocated (budget) 5100 W
Total Power Available for additional modules 6900 W
NEXUS_Qro_MAN02# sh module
Mod Ports Module-Type Model Status
1 48 1000 Mbps Optical Ethernet Module N7K-M148GS-11 ok
2 48 1000 Mbps Optical Ethernet Module N7K-M148GS-11 ok
3 32 10 Gbps Ethernet Module N7K-M132XP-12 ok
4 32 10 Gbps Ethernet Module N7K-M132XP-12 ok
5 0 Supervisor module-1X N7K-SUP1 active *
6 0 Supervisor module-1X N7K-SUP1 ha-standby
7 48 10/100/1000 Mbps Ethernet Module N7K-M148GT-11 ok
8 48 10/100/1000 Mbps Ethernet Module N7K-M148GT-11 powered-dn
Mod Power-Status Reason
8 powered-dn Reset (powered-down) because module does not boot
Mod Sw Hw
1 5.2(3a) 1.2
2 5.2(3a) 1.2
3 5.2(3a) 1.6
4 5.2(3a) 1.6
5 5.2(3a) 1.5
6 5.2(3a) 1.5
7 5.2(3a) 1.5
Mod MAC-Address(es) Serial-Num
1 00-23-eb-3f-ba-74 to 00-23-eb-3f-ba-a8 JAF1329ANFH
2 c4-7d-4f-3b-40-a4 to c4-7d-4f-3b-40-d8 JAF1344ATTR
3 00-23-eb-51-6c-2c to 00-23-eb-51-6c-50 JAF1329ALHJ
4 00-25-84-e4-15-40 to 00-25-84-e4-15-64 JAF1321ARRL
5 00-26-51-bd-57-40 to 00-26-51-bd-57-48 JAF1333AALL
6 00-26-51-bc-e9-c0 to 00-26-51-bc-e9-c8 JAF1332AEPJ
7 00-23-eb-3f-c8-68 to 00-23-eb-3f-c8-9c JAF1333AEFN
8 00-00-00-00-00-00 to 00-00-00-00-00-00 JAF1333AEEP
Mod Online Diag Status
1 Pass
2 Pass
3 Pass
4 Pass
5 Pass
6 Pass
7 Pass
Xbar Ports Module-Type Model Status
1 0 Fabric Module 1 N7K-C7010-FAB-1 ok
2 0 Fabric Module 1 N7K-C7010-FAB-1 ok
3 0 Fabric Module 1 N7K-C7010-FAB-1 ok
Xbar Sw Hw
1 NA 1.1
2 NA 1.1
3 NA 1.1
Xbar MAC-Address(es) Serial-Num
1 NA JAF1333AARS
2 NA JAF1333AARR
3 NA JAF1333AATH
10-18-2013 06:05 AM
It appears that after the upgrade module 8 can't power up any more. Open a ticket with TAC and you may need to RMA the module.
