N9K-C93108TC-EX and N2K-C2248TP-E default powers and fans
jmartinez20
Hello Everyone,
I was not able to find any information regarding both units if they come by default with powers and fans.
Your help is appreciated.
I know this might be a silly question are the powers and fans on the nexus family come by dafult?
N2K-C2248TP-E  and  N9K-C93108TC-EX   come by default with powers and Fans  or need to order them separately at extra cost ?
N9K-C93108TC-EX:
NXA-PAC-650W-PE     QTY:2
NXA-FAN-30CFM-F     QTY:4
N2K-C2248TP-E :
N2K-C2248-FAN=   QTY: 1
N2200-PAC-400W  QTY:  2 or 1  by default  ?
N2K-C2248TP
Cisco Nexus 2000 Series 1GE Fabric Extender, 2PS, 1 Fan Module, 48x100/1000Base-T + 4x10GE (req SFP+), same as N2K-C2248TP-1GE with added choice of airflow and power supply
Reza Sharifi
Yes, both the FANs and the PSUs come with the units. You don't need to order them separately.
The reason for this statement "added choice of airflow and power supply" is that you can get the switches with front to back airflow or back to front depending on your data center and where the cold air is exhausting from.
Reza Sharifi
