NADs send RADIUS accounting too frequently
Hi Gentlemen
i've stack of "WS-C2960S-48LPS-L" running 15.2(2a)E1 & dot1x/mab AAA on the access-ports.
Everything is Ok except stack sends extra RADIUS accounting requests (thousands; every 5 seconds for each already authenticated endpoint; checked with tcpdump on the ISE).
Searching for bug didnt succeed . Can anyone help with it pls?
#show radius server-group radius-dot1x
Server group radius-dot1x
Sharecount = 1 sg_unconfigured = FALSE
Type = standard Memlocks = 1
Server(<IP1>:1812,1813) Transactions:
Authen: 196 Author: 0 Acct: 127678
Server_auto_test_enabled: TRUE
Keywrap enabled: FALSE
Server(<IP2>:1812,1813) Transactions:
Authen: 0 Author: 0 Acct: 338
Relevant config:
aaa group server radius radius-dot1x
aaa authentication dot1x default group radius-dot1x
aaa authorization exec default group radius-dot1x if-authenticated
aaa authorization network default group radius-dot1x
aaa accounting update newinfo periodic 1440
aaa accounting dot1x default start-stop group radius-dot1x
 server name PSN1
 server name PSN2
radius server PSN1
 address ipv4 <IP1> auth-port 1812 acct-port 1813
 automate-tester username <testuser> probe-on ignore-acct-port
 key <ISEKEY>
radius server PSN2
 address ipv4 <IP2> auth-port 1812 acct-port 1813
 key <ISEKEY>
device-sensor accounting
device-sensor notify all-changes
Typical port:
interface GigabitEthernet2/0/40
description ACCESS PORTS
switchport access vlan <DATAVLAN>
switchport mode access
switchport voice vlan <VOICEVLAN>
ip access-group ACL-PreAuth in
authentication control-direction in
authentication event fail action next-method
authentication event server dead action authorize vlan <DATAVLAN>
authentication event server dead action authorize voice
authentication event server alive action reinitialize
authentication host-mode multi-auth
authentication open
authentication order dot1x mab
authentication priority dot1x mab
authentication port-control auto
authentication violation restrict
mab
snmp trap mac-notification change added
dot1x pae authenticator
dot1x timeout tx-period 5
spanning-tree portfast
end
balaji.bandi
is this only on this switch ? what device connected to this switch ( AP / Phone / ?)
worth checking this thread :
https://community.cisco.com/t5/network-access-control/ise-2-1-12929-nas-sends-radius-accounting-update-messages-too/m-p/3314699
BB
Hi Balaji
Yes, it's only switch misbehaving :0) Endpoints r phones & PCs. No flaps on the ports. No ip device tracking events . nothing suspected
i've read the treat u've referred to. not usable unfortunately :0(
Not that i am aware any other bug reported at this stage, may be we need to see what made the device to think sending too many accounting ?
if this is pressing issue or get chance upgrade to latest IOS and check 15.2.2E9
BB
 "may be we need to see what made the device to think sending too many accounting ?" - any idea how?
"if this is pressing issue or get chance upgrade to latest IOS and check 15.2.2E9" - i'm thinking ~it. now i'm trying to open case with TAC as i dont get how to advance
