NAT and PBR
markmarek
I need some help with a Cisco config that would NAT a computer to one IP address if they leave one interface and NAT to a different one if that need to go out another interface
I want to nat a server based on what outbound interface the traffic leaves on with two IP addresses.
If traffic leaves on f0/0 then nat to 10.1.1.1 f0/1 then nat to 10.1.1.2.
manish arora
Level 6
Level 6
Do you have Pbr configured already ? what device are you working on ( asa , router , l3 ) ?
I don't have anything configured yet?
How would I do it for a router and how would I do it for an ASA?
I am going to guide you here to a cisco link for pbr configuration on asa :-
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps6537/ps6586/ps6635/ps6659/prod_white_paper0900aecd8060b477.html
For multiple static nat for a server :-
since you will have two different interfaces to go out of you can following statement on the asa :-
static (inside,outside1) 10.1.1.1 a.b.c.d netmask 255.255.255.255
static (inside,outside2) 10.2.2.2 a.b.c.d netmask 255.255.255.255
I am not sure about the router configuration but the concept should be same, just change of commands.
hope it helps
Manish
