NAT extendable configuration problem
ahummel
Visitor
Currently I am experiencing a problem with a NAT configuration when I want to migrate to a new router. Currently we have a Cisco 3640 router with this NAT config:
ip nat outside source static 10.10.10.1 10.90.3.1 extendable
ip nat outside source static 10.10.10.2 10.90.3.10 extendable
ip nat outside source static 10.10.10.2 10.10.20.2 extendable
ip nat outside source static 10.10.10.1 10.10.20.1 extendable
On the current router with IOS (tm) 3600 Software (C3640-JS-M), Version 12.1(9) the above configuration works just fine.
On a new router with IOS Software, 3800 Software (C3845-ADVENTERPRISEK9-M), Version 12.4(12c) I cannot get this configuration to work.
The first two lines are no problem, but when I want to configure the last two lines I get these messages:
% 10.10.10.2 already mapped (10.90.3.10 -> 10.10.10.2)
% 10.10.10.1 already mapped (10.90.3.1 -> 10.10.10.1)
What the message is saying is actually true, but the extendable keyword should make this possible as far as I know (and it is working fine on the old router). I thought it might be a bug in the new IOS, but I couldn't find any in the bug toolkit myself.
Any thoughts/help would be greatly appreciated.
Meanwhile I will try the newest IOS on the new router to see if it helps solving the problem. I will post the results as soon as I have them.
Kind regards,
Arjan Hummel
8 Replies 8
ahummel
Visitor
The problem remains when I run the latest IOS for this router (c3845-adventerprisek9-mz.124-23.bin). Ofcourse there are many other IOS versions to try, but I would like some more insight on this problem first.
Thanks in advance for any replies!
I wish everybody a very good and NAT-problem-free new year!
Arjan Hummel
Still no solution found. I was wondering if this should work at all. Maybe the old IOS accepts those lines while it shouldn't? Sometimes bugs actually makes things work!
Arjan
Did a bit of testing on a 2621XM running 12.4(1).
I get the same error as you about the address already being mapped. However if you can specify the ports then it allows you to enter it ie.
ip nat outside source static tcp 10.10.10.1 80 10.90.3.1 80 extendable
ip nat outside source static tcp 10.10.10.1 143 10.10.20.1 143 extendable
which actually makes a lot of sense because how does the router know which ports you want to map to which IP address. So i'm guessing the 3640 didn't do it properly.
Jon
Jon,
Thanks for your reply. I am certainly going to try the port number addition in the configuration and will post my findings here. But I am still not sure why it doesn't work in the way I have configured it.
What I didn't mention in my first post is that I also use inside translations on the router. I'll post the full NAT config now. I removed the outside translation for 10.10.10.2 because I don't need it anymore, but that doesn't change the problem I am having.
ip nat pool pool-nat-ing 10.10.10.50 10.10.10.50 netmask 255.255.255.0
ip nat inside source route-map map-ing pool pool-nat-ing overload
ip nat pool pool-nat-ing_alt 10.10.10.60 10.10.10.60 netmask 255.255.255.0
ip nat inside source route-map map-ing_alt pool pool-nat-ing_alt overload
route-map map-ing_alt permit 10
match ip address acl-nat-ing-10.10.10.60
route-map map-ing permit 10
match ip address acl-nat-ing-10.10.10.50
ip access-list extended acl-nat-ing-10.10.10.50
permit ip host 10.101.19.1 host 10.90.3.1
ip access-list extended acl-nat-ing-10.10.10.60
permit ip host 10.10.20.40 host 10.10.20.1
What I see on the old router is that when a packet gets translated the port numbers are also kept in the NAT table. As far as I know this is due to the route-maps and extendable keyword being used:
Pro Inside global Inside local Outside local Outside global
tcp 10.10.10.50:3774 10.101.19.1:3774 10.90.3.1:7000 10.10.10.1:7000
So a full translation (including port numbers) is kept in the NAT table as seen above. I don't mention port numbers in the configuration, the IOS obviously keeps track of those automatically (at least the old IOS does).
When reviewing the information below, one should think my configuration should work (as it does on the old router). This information comes from the page http://www.cisco.com/en/US/technologies/tk648/tk361/tk438/technologies_white_paper09186a0080091cb9.html
• "Extendable" static translations:
The extendable keyword allows the user to configure several ambiguous static translations, where an ambiguous translations are translations with the same local or global address.
ip nat inside source static extendable
Some customers want to use more than one service provider and translate into each provider's address space. You can use route-maps to base the selection of global address pool on output interface as well as an access-list match. Following is an example:
ip nat pool provider1-space ...
ip nat pool provider2-space ...
ip nat inside source route-map provider1-map pool provider1-space
ip nat inside source route-map provider2-map pool provider2-space
route-map provider1-map permit 10
match ip address 1
match interface Serial0/0
route-map provider2-map permit 10
match ip address 1
match interface Serial0/1
Once that is working, they might also want to define static mappings for a particular host using each provider's address space. The software does not allow two static translations with the same local address, though, because it is ambiguous from the inside. The router will accept these static translations and resolve the ambiguity by creating full translations (all addresses and ports) if the static translations are marked as "extendable". For a new outside-to-inside flow, the appropriate static entry will act as a template for a full translation. For a new inside-to-outside flow, the dynamic route-map rules will be used to create a full translation.
Am I missing something here?
Arjan Hummel
Jon,
This won't work for me, because I need to have the same port number (7000) for both translations. When I try your config including the portnumbers I get the same error message. Again, it's working fine on the current router. Here's a larger portion of the NAT table on the current router:
--- --- --- 10.90.3.1 10.10.10.1
--- --- --- 10.10.20.1 10.10.10.1
tcp 10.10.10.50:1028 10.101.19.1:1028 10.90.3.1:7000 10.10.10.1:7000
tcp 10.10.10.50:1041 10.101.19.1:1041 10.90.3.1:7000 10.10.10.1:7000
tcp 10.10.10.50:1047 10.101.19.1:1047 10.90.3.1:7000 10.10.10.1:7000
tcp 10.10.10.50:1720 10.101.19.1:1720 10.90.3.1:7000 10.10.10.1:7000
Again, this table exists without any port numbers mentioned in the running NAT configuration!
Kind regards,
Arjan Hummel
Wouter Prins
Level 2
Level 2
i've never seen extendable being used without portnumbers, my guess is that your old router has a bug. 🙂
hetene_kaz
Your configuration is incorrect. Static NAT cannot point one address (10.10.10.1) to two addresses the same time. How do you expect router to translate 10.10.10.1? What string should it use if it has two??!
Solution: You need to define either the protocol & port number or define only one string.
Hello Hetene,
I am going to try this, but I am not sure this is actually the case. Please see my reply on the post from Jon for more inormation.
Arjan
