NAT in Cisco 3750 Switch
Lavanholy
I have a peculiar question.That,I have Cisco3750 switch,in which I have created 3 VLANs,named VLAN10,VLAN20 and VLAN 30
Thne in VLAN 10,I have a server with the static IP address in that VLAN subnet,then I have configured VLAN interface 10,20 and 30 for inter VLAN communication.(By enabling the IP routing)
My requirement is the server which is in VLAN 10 has to be natted to VLAN 20 and VLAN 30 Is it possible?Basically a static NATTING.....
Please hep me.
My guess: Basically a VLAN interface is a virtual,it is not a physical,in that case static natting may not be possible.
If it is a physical port,atleast we could convert it as a ROUTED PORT,then atleast we can use the IP NAT inside etc...
Thanks and Regards,
S.Venkataraman.
Jon Marshall
The 3750 does not support NAT. The only switch that you can still purchase that will do NAT is the 6500 so you may be better off looking to a low end router to do the NAT.
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a008011c629.shtml
Jon
samuelpetrescu
Sorry, Cisco 3750 switches doesn’t support NAT
at all, and is no planning for NAT support.
Ganesh Hariharan
Please hep me.
Thanks and Regards,
S.Venkataraman.
Hi S.Venkataraman,
Check out the below link with switches details which support NAT Feature Support on Catalyst Switches
http://www.cisco.or.at/en/US/tech/tk648/tk361/technologies_tech_note09186a008011c629.shtml
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
