NAT issue
ruliffilur
Hello
I?ve got a NAT problem on a Cisco 1721 router with an IOS version of 12.4.12. I cant get NAT to work at all, have configured the usual "ip nat inside/outside" "ip nat inside source list 1 int <my internal interfance> overload and a access list for my internal network this is my old config from version 12.2:
version 12.2
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname Stormwind
no logging console
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip audit notify log
ip audit po max-events 100
vpdn enable
vpdn-group 1
! Default L2TP VPDN group
! Default PPTP VPDN group
accept-dialin
protocol any
virtual-template 1
interface Ethernet0
description Interface to Home LAN
ip address 172.16.25.1 255.255.255.0
ip nat inside
half-duplex
interface FastEthernet0
description Interface to WAN Internet
ip address dhcp
ip nat outside
speed auto
interface Serial0
no ip address
shutdown
interface Virtual-Template1
description Interface for VPN connections
ip unnumbered FastEthernet0
no keepalive
peer default ip address pool test
ppp encrypt mppe 128
ppp authentication ms-chap
ip local pool test 172.16.25.11 172.16.25.20
ip nat inside source list 1 interface FastEthernet0 overload
ip classless
no ip http server
ip pim bidir-enable
access-list 1 permit 172.16.25.0 0.0.0.255 log
access-list 1 remark NAT accesslist
no cdp run
line con 0
login local
line aux 0
login local
line vty 0 4
login local
transport preferred ssh
transport input ssh
transport output ssh
line vty 5 15
login local
transport input ssh
no scheduler allocate
end
I used this on a Cisco 1720 and also a 1605 that one with a 12.3 ios and it worked just fine. On the other hand this 1721 wont nat a packet. I dont get any hits in the access list nor the nat translation table. Once difference I?ve noticed is that the 1721 activates a nvi0 interface the others didnt, have nat configurations changed in ios 12.4? Also tried this "NAT on a Stick" with my 1721 and it worked fine, I could nat from my local physical router interface to a loopack without any problems.
So anyone that can help with this problem?
//Johan
ovt
Level 8
Level 8
Remove "log" from your "access-list 1" and it will work just fine.
6 Replies 6
ovt
Level 8
Level 8
Thank you it works now.
Can anyone explain the above behavior when the log keyword was used.
The log keyword at the end of the individual ACL entries shows the ACL number and whether the packet was permitted or denied, in addition to port-specific information.
hope to help ... rate if it does ....
Hi Sourabh,
I know the use of the log keyword in an access-list.
What i want to understand is how the nAT started working if you remove the Log keyword
I guess that NATing is performed in CEF switching path and "log" requires all packets to be sent via process switching path. This might be the source of the problem.
