NAT problem , the CPU becomes FULL
mendrika13
We have got some problem in our router (a 1841, IOS Version 12.4(15)T12),
I activated the command "debug ip packet" (to observ nat translation) then the cpu became full (100%) and I wasn't able to reach the management IP of it.
After restarting the router, I can reach it BUT the cpu still in very high average 80-100% and we have loss some packets.
What should we do to decrease the CPU utilisation?
How can I be sure that the debug ip packet is off ? (I tried the command "show debugging {condition} {all}" but no result)
Thank you
chris noon
Use the command:
# undebug all
This will turn off all debugging
Ganesh Hariharan
NAT translation debug command is
debug ip nat
Which would give you the  translations being created on the device as well as packets that are being translated using the NAT translations.
debug ip packet
This debug command essentially shows all the packets that hit the access list for which this command is used. It is also useful for troubleshooting NAT issue but recommended to use with proper ACL to get the actual packet insight.
To stop all debugging.
Just type Undebug all
Hope it Helps
-GI
