NAT PROBLEM
smavashev
2801 Router
SVI from 3550 192.168.20.0 0.0.0.255
ip dhcp pool
network 192.168.20.0 255.255.255.0
default-router 192.168.20.1
int fa0/0
ip nat inside
int fa0/1
ip nat outside
access-list 100 permit ip 192.168.20.0 0.0.0.255 any
ip nat inside source list 100 interface fa0/1 overload
****** the dhcp bindings are translating ****, nat is not translating - is there another way to configure a NAT statements ????
7 Replies 7
cadet alain
on which device are you doing NAT? post output from:
-sh ip int br | exc una
- sh ip route
Regards.
Alain
I could not paste from output because it's on a different computer but I wrote it out.
NVI0                                                          unassigned                 NO            unset         up
Router# show ip route
Gateway of last resort is 0.0.0.0 to network 0.0.0.0
            67.0.0.0/8 us variably subnetted, 2 subnets, 2 masks
D            67.0.0.0/8 is a summary, 00:00:22, Null0
C            67.85.96.0/21 is directly connected, Fastethernet 0/1
D            192.168.20.0/24 [90/28416] via 10.1.1.2, 00:01:00, Fastethernet 0/0
               10.0.0.0/8 is variably subnetted, 2 subnets, 2 subnet masks
C                  10.1.1.0/24 is directly connected, Fastethernet 0/0
D                  10.0.0.0/8 is a summary, 00:00:22, Null0
S               167.206.195.6 [254/0] via 67.85.96., Fastethernet 0/1
S*            0.0.0.0 is directly connected, FastEthernet 0/1
Sh ip int brief
Interface                         IP address         Ok?     Method    Status
Fasthethernet 0/0            10.1.1.1             Yes     Manual      up
Fastethernet  0/1             67.85.101.117    Yes      NO            up
I'm doing the config on the 2801 Router, my svi LAN is 192.168.20.0
can you modify your default route and configure it with next-hop instead of outgoing interface.
Regards.
Alain
I have changed my default route to 0.0.0.0 0.0.0.0 to fastethernet 0/0 if that was what you were reffering too, i also changed the default router on SVI to 10.1.1.1 .
10.1.1.1 is the Fa0/1 interfafce on 2801
But still no luck, is my NAT configuration correct ? maybe I can configure again from scratch. ???
I'm sorry F0/0 is the 10.1.1.1 on 2801 router, and 10.1.1.2 is Fa0/9 switchport interface on 3550.
you had something like this: ip route 0.0.0.0 0.0.0.0 f0/1 and you should change to something like this:
ip route 0.0.0.0 0.0.0.0 67.85.x.x  which is the ISP default gateway they gave you.
Regards.
Alain
