nat Question
stoneystone
I have a question about nat. I have the following config in a ASA firewall:
nat (outside) 4 10.0.0.99 255.255.255.255
nat (outside) 4 10.0.1.66 255.255.255.255
nat (outside) 4 10.0.0.128 255.255.255.255
nat (outside) 4 10.0.1.0 255.255.255.0
nat (outside) 0 10.1.0.0 255.255.255.0
nat (outside) 0 10.2.0.0 255.255.255.0
Are there nat commands that are doing the same? If I understand nat'ing, this command:
covers these commands
And these:
covers?
are doing the same thing.
Also,
nat (name) 5 172.19.0.222 255.255.255.255
nat (name) 2 172.19.0.0 255.255.255.0
Which command will the FW look at first? Is the first command necessary?
I would appreciate an explanation of these natting commands. I have a situation of many natting commands and it looks like some are doing the same thing.
Please rate the post.. if the answer was helpful
Hitesh Vinzoda
Hitesh Vinzoda
Level 10
Level 10
The security appliance matches real addresses to NAT commands in the following order:
1. NAT exemption (nat 0 access-list)-In order, until the first match. Identity NAT is not included in
this category; it is included in the regular static NAT or regular NAT category. We do not recommend
overlapping addresses in NAT exemption statements because unexpected results can occur.
2. Static NAT and Static PAT (regular and policy) (static)-In order, until the first match. Static
identity NAT is included in this category.
3. Policy dynamic NAT (nat access-list)-In order, until the first match. Overlapping addresses are
allowed.
4. Regular dynamic NAT (nat)-Best match. Regular identity NAT is included in this category. The
order of the NAT commands does not matter; the NAT statement that best matches the real address
is used. For example, you can create a general statement to translate all addresses (0.0.0.0) on an
interface. If you want to translate a subset of your network (10.1.1.1) to a different address, then you
can create a statement to translate only 10.1.1.1. When 10.1.1.1 makes a connection, the specific
statement for 10.1.1.1 is used because it matches the real address best. We do not recommend using
overlapping statements; they use more memory and can slow the performance of the security
appliance.
Hitesh Vinzoda
Hitesh,
Thanks for the explaination. I appreciate your time.
Hitesh Vinzoda
