06-06-2018 08:46 AM - edited 03-08-2019 03:16 PM
Hello Guys,
recently i bought one 887 and 881 routers to connect them to my ISP modem, but i notice that NAT seems is not supported, so like that i cannot use the router because to send the traffic to the ISP i need nat overload.
is there any solution for these routers to support Nat, for example change the IOS version?
IOS version: (C880DATA-UNIVERSALK9-M), Version 15.1(4)M
Kind regards,
06-06-2018 09:36 AM
What is the IOS you are running and what is the error message you are getting when you try to configure NAT?
Also, what is the license level?
06-06-2018 09:37 AM
Router(config)#int Fa0
Router(config-if)#ip nat
Router(config-if)#ip nat ?
% Unrecognized command
looks like the router doesn't accept the command so it is not supported by this router.
06-06-2018 10:15 AM
Nat works only as below, but the issue the LAN ports is assigned to vlan 2 and i have multiples vlans on the access switch, so traffic will be blocked and only vlan2 traffic will be allowed, i have no idea how to make it works with NAT.
i can only configure the NAT under the VLAN and i should assign the VLAN to the LAN and WAN interfaces to get internet access only for VLAN 2 users.
interface FastEthernet0
switchport access vlan 3
no ip address
interface FastEthernet1
switchport access vlan 2
no ip address
interface Vlan2
ip address 10.10.10.1 255.255.255.0
ip nat inside
ip virtual-reassembly in
interface Vlan3
ip address 192.168.100.13 255.255.255.0
ip nat outside
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface Vlan3 overload
ip route 0.0.0.0 0.0.0.0 192.168.100.1
logging esm config
access-list 1 permit 10.10.10.0 0.0.0.255
end
Router#
Router#
Router#
Router#ping 8.8.8.8
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/5/12 ms
07-10-2018 03:42 AM
07-10-2018 01:41 AM
