NAT & Unicast to Multicast Conversion
soni.sunil
I am trying to simulate two below scenarios, and finding some difficulties in implementation, and really need your support, please have a look if you can point out something.
Scenario One:-
I am planning to get the unicast streams from different 2-3 sources over internet, and I am doing NAT for port-forwarding all those unicast streams to a one private IP. Attached is the setup for your understanding.
Setup: - Both unicast streams will be hitting to One Public IP (3.3.3.2) on UDP/TCP Port 1234, 1236 & 1238 only & the same ports need to be forwarded to natted One Private IP (10.10.10.4)
My motive is to,
  • •1) NATTING these 2 unicast streams into one private IP(10.10.10.4) by checking Source & Destination based IP’s and ports, but in below configuration I cannot achieve on checking Source & Destination based IP’s and ports
Router configuration:-
interface GigabitEthernet0/0
description ***Connected to Internet ***
ip address 3.3.3.2 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip virtual-reassembly in
load-interval 30
duplex auto
speed auto
interface GigabitEthernet0/1
description ***Connected to Cisco 2900 Switch***
ip address 10.10.10.1 255.255.255.0
ip nat inside
load-interval 30
duplex auto
speed auto
ip nat inside source static tcp 10.10.10.2 1234 3.3.3.2 1234 extendable
ip nat inside source static udp 10.10.10.2 1234 3.3.3.2 1234 extendable
ip nat inside source static tcp 10.10.10.2 1236 3.3.3.2 1236 extendable
ip nat inside source static udp 10.10.10.2 1236 3.3.3.2 1236 extendable
ip nat inside source static tcp 10.10.10.2 1238 3.3.3.2 1238 extendable
ip nat inside source static udp 10.10.10.2 1238 3.3.3.2 1238 extendable
Scenario Two:-
I am planning to get the unicast streams from different 2-3 sources over internet, and I am doing NAT for converting these unicast streams into multicast streams. Attached is the setup for your understanding.
Setup: - Both unicast streams will be hitting to One Public IP (3.3.3.2) on UDP/TCP Port 1234, 1236 & 1238 only & the same these 3 ports need to be forwarded on Natted these 2 multicast IPs 239.200.1.1 & 239.200.1.2
My motive is to,
  • •1) Convert these 2 unicast streams by NATTING into 2 multicast unique streams using Source based IP’s and ports, but in below configuration I cannot achieve checking Source based IP’s and ports for converting to have 2 multicast IPs with same ports and cannot receive/join these multicast
ip multicast-routing
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip pim sparse-mode
load-interval 30
duplex auto
speed auto
ip nat inside
ip pim sparse-mode
load-interval 30
duplex auto
speed auto
interface Loopback0
description ***RP for Multicast***
ip address 10.10.40.1 255.255.255.255
ip pim sparse-mode
ip pim rp-address 10.10.40.1
ip nat inside source static udp 239.200.1.1 1234 3.3.3.2 1234 extendable
ip nat inside source static udp 239.200.1.1 1236 3.3.3.2 1236 extendable
ip nat inside source static udp 239.200.1.1 1238 3.3.3.2 1238 extendable
ip nat inside source static udp 239.200.1.2 1234 3.3.3.2 1234 extendable
ip nat inside source static udp 239.200.1.2 1236 3.3.3.2 1236 extendable
ip nat inside source static udp 239.200.1.2 1238 3.3.3.2 1238 extendable
Hello Soni
I wonder if that worked for you.
There is a feature that may solve your issue:
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/ipmulti_serv/configuration/xe-3s/imc-serv-xe-3s-book/imc_service_reflect.html
Ed
