05-06-2015 08:08 AM - edited 03-07-2019 11:53 PM
Has anyone run across a ErrorEPC while trying to boot a Cisco 720-3C?
05-08-2015 06:17 AM
Can you please paste the error here.
Madhu
05-08-2015 07:29 AM
Sure thing:
$0 : 00000000, AT : 46AE0000, v0 : 452D0000, v1 : 00000000
a0 : 4A5B9478, a1 : 00008100, a2 : 00000000, a3 : 00000D0E
t0 : 00000028, t1 : 34008101, t2 : 34008100, t3 : FFFF00FF
t4 : 440B7AB0, t5 : 52455345, t6 : 80000000, t7 : 6E672072
s0 : 00000000, s1 : 00000000, s2 : 46960000, s3 : 46AF0000
s4 : 46970000, s5 : 46970000, s6 : 45300000, s7 : 50458178
t8 : 00000000, t9 : 424B8598, k0 : 00000000, k1 : 00000000
gp : 46AE8F10, sp : 50458110, s8 : 46970000, ra : 440CBBBC
EPC : 440CBFEC, ErrorEPC : FFEFFFFF, SREG : 34008103
MDLO : 00005A92, MDHI : 00004000, BadVaddr : 00000000
TEXT_START : 0x40102B18
DATA_START : 0x462C9C60
Cause 00000824 (Code 0x9): Breakpoint exception
Writing crashinfo to bootflash:crashinfo_RP_20150505-183431-UTC
18:34:31 UTC Tue May 5 2015: Breakpoint exception, CPU signal 23, PC = 0x440CBFEC
Hank
05-08-2015 09:24 AM
This is from a crash file. What is the real issue? Are you looking for the reason for switch crash?
If so please share the complete crashfile as an attachement. I see this is from bootflash. Yoy may also look for a crashfile under sup-bootflash: OR sup-bootdisk:
Once you share it I will try to let you know the answer.
Madhu
