NAT using VLANs
dgambrill
Community Member
Hi. Trying to do NAT on a MSFC using vlan interfaces. Have one outside and one inside interface and many other vlan interfaces on the msfc. SInce there are many interfaces the traffic isnt forced to go through the outside interface to get to the inside one. Need a way to control the traffic. Issue may have to do with MLS as well. It works if I test with a pc in the outside vlan, but if I move it to another vlan, it does not.
thanks in advance
vijayasankar
Level 9
Level 9
Can you the post the configuration that you have tried(excluding any sensitive details like public ip etc..) and your setup details.
-VJ
mahmoodmkl
Level 11
Level 11
hi
Did you define the access-list for specified traffic which u want to nat.
Mahmood
