Nating to Layer 3 Switch with SVI VLAN Interfaces
Colourful
I have a design which involves using a Layer 3 switch to control the internal routing. (Layer 3 Intervlan routing, See attached Document - Requires Microsoft Visio). My question is - how would I tell the ASA Firewall to NAT to an internal vlan that is behind the Layer 3 Switch, I am familar with Nating but only on a Router on a stick basis.
Kind regards,
Jake
Abzal
Level 7
Level 7
If ASA is directly connected to the router then should like this
ASA:
nat (inside) 1 0.0.0.0 0.0.0.0
global (outside) 1 interface
Then if you are not running dynamic routing protocol you need to add static routes:
For example:
route inside 192.168.0.0 255.255.255.0 10.0.0.1
And default static route to outside:
route outside 0.0.0.0 0.0.0.0 1.1.1.1
http://www.cisco.com/en/US/docs/security/asa/asa82/configuration/guide/route_static.html
http://www.cisco.com/en/US/docs/security/asa/asa82/configuration/guide/nat_dynamic.html
On L3 switch you also will need static route.
ip route 0.0.0.0 0.0.0.0 10.0.0.2
Sent from Cisco Technical Support Android App
Best regards,
Abzal
