native vlan for trunks
vishalpatil86
Level 7
Level 7
HI,
I have core and edge switch. core's gig3/2 is connected to edge's gig0/1.
RUN CONFIG is -
core#sh run int gig3/1
Building configuration...
Current configuration : 130 bytes
interface GigabitEthernet3/1
switchport trunk native vlan 10
switchport mode trunk
end
core#sh run int vlan 10
Current configuration : 102 bytes
interface Vlan10
ip address 172.16.10.253 255.255.255.0
end
edge#sh run int gig0/1
Current configuration : 92 bytes
interface GigabitEthernet0/1
end
edge#sh run int vlan 10
Current configuration : 121 bytes
interface Vlan10
ip address 172.16.10.246 255.255.255.0
no ip route-cache
end
trunk config -
core#sh int gig3/2 trunk
Port        Mode             Encapsulation  Status        Native vlan
Gi3/2       on               802.1q         trunking      10
Port        Vlans allowed on trunk
Gi3/2               1-4094
Port                Vlans allowed and active in management domain
Gi3/2               1-2,10,20-23,99,201-207,209-212,214-222,301-312,314-330,332-333,401-407,409-412,414-433,501-503,509-512,514-527,532-533,601-607,609-612,614-633,701-707,709-712,714-733,801-807,809-812,814-833,901-906,909-912,914-922,924-925,927-933,3000,3080-3092,4000-4001
Port                Vlans in spanning tree forwarding state and not pruned
edge#sh int gig0/1 trunk
Gi0/1       on               802.1q         trunking      10
Gi0/1       1-4094
Gi0/1       1,10,99,201-207,209-212,214-222,301-307,309-312,314-330,332-333,4000-4001
following are the switch port config of core and edge switch respectively -
core#sh int gig3/2 switchport
Switchport: Enabled
Administrative Mode: trunk
Operational Mode: trunk
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: dot1q
Negotiation of Trunking: On
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 10 (mgt)
Administrative Native VLAN tagging: enabled
Voice VLAN: none
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk Native VLAN tagging: enabled
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk associations: none
Administrative private-vlan trunk mappings: none
Operational private-vlan: none
Trunking VLANs Enabled: ALL
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
Appliance trust: none
edge#sh int gig0/1 switchport
Switchport: Enabled
Trunking Native Mode VLAN: 10 (NIMS_mgt)
Voice VLAN: none
Protected: false
I just have one question,
how native vlan works here? pls help me on this. i am struggling with this concept
6 Replies 6
cadet alain
Hi vishal,
the native vlan on a dot1q trunk is the vlan which isn't tagged. by default it is vlan1 and it must be equal on both ends of the trunk.
Regards.
Alain.
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained  within this  posting without consideration and with the reader's  understanding that  there's no implied or expressed suitability or  fitness for any purpose.  Information provided is for informational  purposes only and should not  be construed as rendering professional  advice of any kind. Usage of this  posting's information is solely at  reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
As Alain noted, the native vlan is where untagged frames are directed that are received on a trunk.  Outbound packets, including the native vlan, should be tagged.  I.e., received native vlan frames could either be tagged or not.
Not 100% sure, but not all vendors might support native vlans, i.e. untagged frames on a trunk.  The feature is really there to allow acceptance of untagged frames that "somehow" are received on a trunk.
PS:
If you're wondering why the sender should tag native vlan frames, outbound.  Remember there's also a CoS field in the frame besides the vlan ID.
I don't understand this sentence:
Aren't these 2 verbs mutually exclusive ?
Then these are not native vlan frames anymore ? I'm a little bit confused by your answer.
let's suppose we have this:
switchport mode access
switchport access vlan 10
switchport voice vlan 10
the data vlan 10 frames will be untagged by default but the PC shouldn't be doing any QoS here only the IP phone.
now  let's suppose we have a trunk to a VM then we could tag all frames but  then they wouldn't be the native vlan on the switch trunk going to other  switch because then by default the native vlan is vlan1.
I always thought this a was a backward compatibility feature for devices not understanding Dot1q.
Can you clarify for me please.
Regards.
Alain.
Alain
I am also a little confused by that sentence
However in reference to another point you make -
It basically is and we always describe the native vlan as the vlan with untagged packets. But you can if you want tell the switch to add tags to even the native vlan if you want.  You may want to do this for CoS as indicated by Joseph or you may want to do it for security reasons.
Technically, if you do this then the description of the native vlan as the vlan with untagged packets is not strictly accurate but with 802.1q there always is a native vlan whether you want it or not ! So it is probably correct to say the native vlan is the vlan on an 802.1Q trunk that does not have frames tagged unless you explicitly tell the switch to tag these packets.
Jon
Hi Jon,
Thanks for this clarification.
Regards.
Alain.
Disclaimer
Posting
What I saying doesn't have to be mutually exclusive verbs.
I believe a trunk port receiving tag frames will always consider such frames to belong to the vlan they're tagged with.  A trunk port receiving untagged frames will consider them part of the vlan that's been configured as the native vlan.  In other words, the vlan that's configured as native, can accept frames either tagged or untagged.  (I think that's true, but I haven't doubled checked and it's been a while since I've looked that deeply in vlan tag processing.)  This is the could part, for the configured native vlan, inbound frames could be tagged or not.
For a trunk port sending frames, I'm saying all frames should be tagged, even those for the configured native vlan.  (Not really native then, as Jon points out, but bear with me.)  This so other tag information, like CoS, is available.  But this, as Jon noted, is optional.  Why wouldn't you want to tag all frames?
My understanding about the whole point of native vlans, was to allow devices that couldn't handle tag frames to have their frames assigned to a vlan.  For example, you have two switches that have trunk ports which connect through a hub.  Also connected to the hub are other devices that don't know how to tag frames.  Two vlan capable switches can easily exchange tagged frames between themselves, but the other devices require untagged frames.  The native vlan allows these other host frames to be assigned to a vlan and so they are accepted by either switch.  It also allows the switches to "natively" (i.e. no tag) send frames to these hosts, but only frames for a particular vlan.
All fine and good, but where things can get interesting, switch 1 can assign untagged frames to vlan X while switch 2 can assign untagged frames to vlan Y.  If all frames were tagged, again the should, this mismatch isn't possible.  But if the native vlan wasn't possible, we couldn't support a mixture of tagged and untagged frames on the same wire.
More interesting, if the two switches don't agree on what's a native vlan, the receiving switch is getting untagged frames from hosts, which it "natively" assigns to vlan X but it may get tagged frames for vlan X from the other switch because its configured vlan Y as its native vlan.
PS:
Oh, on your question using a voice and data vlan using the same port, that's sort of a special case, as the port isn't really considered a trunk port although it processes "native" and tagged frames.
