Natting Issue
imranraheel
I ahve a NATTING issue. The WAN link is on Serial Interface and the Lan is connected to Fast Ethernet 0.I am doing natting but the clients behind the router are not been able to access Internet I ahve attached running configurations Kindly recheck the configurations and do let me know what is the issue.
Edison Ortiz
Your NAT configuration looks fine but you have to keep in mind that in order to access the internet, you also need DNS for name resolution.
You can verify the internet is working by pinging www.yahoo.com by using its ip address instead of the name (69.147.114.210).
mahmoodmkl
Level 7
Level 7
Can u remove the log option from the access-list and try.
Mahmood
IP routing was disabled.Now it is working fine
