Natting with DHCP for home
skhawari83
I want to use a cisco 2911 to work at home.
Current setup:
-I am using a cable internet
-The cable is connected to Thomson Technicolor DCM476 Cable Modem DOCSIS 3.0.
-The Ethernet plug from the modem is going to the wifi router
-The ip address that i am getting from the ISO is not static
Desired Setup:
-Need to connect the Ethernet connector coming from the cable modem to F0/0 of the router
-Connect the F0/1 to a cisco switch
Running-config:
I have followed so many article to implement this solution that my running config is a mess. I would appreciate if other configuration are also checked.
Router-A#show running-config
Building configuration...
Current configuration : 1595 bytes
version 15.1
hostname Router-A
boot-start-marker
boot-end-marker
no logging console
enable secret 5 12345
enable password 12345
no aaa new-model
no process cpu extended history
no process cpu autoprofile hog
dot11 syslog
ip source-route
ip cef
no ip domain lookup
no ipv6 cef
voice-card 0
license udi pid CISCO2811 sn 12345
redundancy
interface FastEthernet0/0
ip address dhcp
ip nat outside
ip virtual-reassembly in
no ip route-cache cef
no ip route-cache
duplex full
speed auto
no cdp enable
no mop enabled
interface FastEthernet0/1
ip address 192.168.1.254 255.255.255.0
ip nat inside
no ip route-cache
duplex auto
speed auto
no cdp enable
interface Serial0/0/0
no ip address
shutdown
no fair-queue
clock rate 125000
interface Serial0/0/1
no ip address
shutdown
clock rate 125000
no cdp enable
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 7 interface FastEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 10.193.44.1
logging esm config
access-list 7 permit 192.168.1.0 0.0.0.255
control-plane
line con 0
exec-timeout 0 0
line aux 0
line vty 0 4
password 12345
login
transport input all
scheduler allocate 20000 1000
end
Philip D'Ath
Delete:
Add:
ip route 0.0.0.0 0.0.0.0 dhcp
