NBAR
sreeju balan
Community Member
Dears,
I would like to do application traffice classification using NBAR,if i configure my router with the following configuration,even it will work without install the pdlm for each protocol,
Router(config) # class-map match-any peer-to-peer
Router(config-cmap) # match protocol gnutella
Router(config-cmap) # match protocol kazaa2
Router(config-cmap) # match protocol napster
Router(config-cmap) # match protocol fasttrack
Router(config-cmap) # match protocol novadigm
Router(config-cmap) # match protocol edonkey
Router(config-cmap) # match protocol bittorrent
Router(config)# policy-map drop-peer-to-peer
Router(config-pmap)# class peer-to-peer
Router(config-pmap)# drop
Router(config)# Interface fastethernet 0/0
Router(config-if)# ip nbar protocol-discovery
Router(config-if)# service-policy input drop-peer-to-peer
Hitesh Vinzoda
Level 10
Level 10
I dont understand what question you want to make? but it seems that you have configured this class-map and want to know whether it will work without PDLM or not ?
So answer is yes...!!
When you create a class map and under it if you match PROTOCOL , it will show you the protocols for which it has the PDLM within the IOS, so you need to require PDLM to be downloaded to router. If any protocol you are trying to match is not listed there than you have to download the PDLM for that protocol to the IOS to use it under class map.
Hope this answers your question..!
Hitesh Vinzoda
Please rate useful posts
