Need basic help extending network using two old 3550-12G switches
dukegrad98
Community Member
Greetings.  I am an "old noob," who twenty years ago made a living working in technology...but my knowledgebase is now an unfortunate combination of rusty and outdated.  I am here requesting help of the most annoying sort -- I need some guidance on how to make my Cisco equipment do far less than it is capable of doing!  I have to think this is easy, but in spite of beating my head against it and nearly wearing out the Google and Youtube servers the past few nights, I have not made any progress and have finally given in to this plea for help.
The scenario seems very simple:  I am trying to extend my internet connection from my home to a detached garage/workshop as well as a guest house.  A flat network is just fine.  The hardware is a hodgepodge of newer consumer-level equipment and older Cisco equipment that I have sitting around from a long-ago business.  Here is roughly what I need the "new leg" of the network to look like this:
Cablemodem/Router --1--> Media Converter --2--> Switch #1 --3--> Switch #2 --4--> (TBD:  Switch / WiFi Access Points / End Users)
Notes/specifics on the equipment involved:
  • Cablemodem/Router:  Netgear C3000, a consumer-grade integrated cablemodem, router, and WiFi access point.
  • Media Converter:  TP-Link MC220L, a little box with 1000Base-T copper link input from the cablemodem/router to output on a Cisco GLC-SX-MM SFP (1000Base-SX).
  • Switch #1 and #2:  vintage Cisco 3550-12G models.  Yes, I have console access through putty.  For those who have forgotten, each switch has ten GBIC ports (all of mine populated with 1000Base-SX adapters) and two 1000Base-T ports.
Notes/specifics on the numbered links between the pieces of equipment:
  • Link 1:  a 2' copper ethernet cable, taking gigabit ethernet from a cablemodem/router port to the media converter.
  • Link 2:  a 300m/1000' multimode fiber (50/125) from the media converter to port Gi0/1 on switch #1, using a Cisco GLC-SX-MM SFP transceiver.
  • Link 3:  a 250m/800' multimode fiber (50/125) connection, from port Gi0/3 on switch #1 to port Gi0/5 on switch #2.
  • Link 4:  is / will be a standard copper gigabit ethernet connection from switch #2 port Gi0/12 to whatever other dumb switch or end user device(s) I wind up using.  Odds are that it will be a fairly typical gigabit switch, with connections to a couple of 1000Base-T hard-wired machines and two or three WiFi access points.
NOW, FINALLY, TO THE QUESTION...!  How do I configure this to work?!?  I basically just need my internet signal relayed/extended.  I don't need the switches to route, or provide DHCP, or segment V-LANs, or firewall, or any of that.  The cablemodem/router will do all of that adequately for my purposes, as long as equipment attached to the switches can see the Netgear in the first place.
I basically just need a link between cablemodem/router and the "TBD end users" after Link 4.  I've gone eight rounds with it in a makeshift lab, to avoid the inconveniences that come once I spread out the equipment across a quarter-mile of fiber.  I once managed to ping the internet from Switch #1 console, but plugging my laptop into its Gi0/11 port still produced no internet access -- and it logically follows that I have never gotten signal to Switch #2.  I do have link lights on both switches, so I know they are physically connected, adapters are working, fiber is good, etc.  I have fiddled with more switchport mode access and spanning-tree portfast and no shut commands than I can count.  Even assigning those configurations to ALL PORTS on the switches (supposedly turning them into "dumb switches") has not resulted in any forward progress.
I have to believe that this setup cannot be that complicated.  I'm sure someone will say I should go buy a dumb switch or two, but I figure it makes perfect sense to use the stuff already sitting around collecting dust.  (Plus, there's the fun of the challenge...or at least it was fun when I started!)  I am just too far out of the loop to sort it out, and I'd be deeply grateful for any tips or configuration command suggestions.
Thanks!
John
Jared Burton
Frequent Visitor
Frequent Visitor
My two cents: The break could be in any one of those devices or even the transceivers. I don't have much experience with media converters, but I understand the desire/necessity with 12g model switches. Most 12g's after the 3550 eliminated copper ports all together.
I would try building your network out piece by piece, starting with the fewest possible pieces.
1. Router -copper- Switch1 -copper- PC. (if that works, add the second switch into the mix)
2. Router -copper- Switch1 -copper- Switch2 -copper- PC (I can't recall if the 3550 has auto mdix, you may want to find or make a crossover cable for the switch to switch connection.)
3. Router -copper- MediaConverter -fiber- Switch -fiber- Switch -Copper- PC
Keep it all on vlan 1 and let it ride. Curious to see what happens, love these make shift projects!
Cheers!
Leo Laohoo
 I am not sure if other non-Cisco switches support 802.1q trunking, but if they do, enable Trunking on the 3550.  Even though you've got a flat Layer 2 network, it's still worth doing Trunking.
If the switches don't support trunking then put the ports into access ports (VLAN 1 default) and disable spanning-tree portfast.
Ports facing directly to PCs then enable portfast, of course.
Jared Burton
Frequent Visitor
Frequent Visitor
Cheers!
Jared, thanks for the brilliant and logical advice on testing strategy.  After a few late nights -- probably counterproductive -- I gave it a whirl your way.
Number 1 worked.  I had to skip Number 2 for the reason you anticipated -- the 3550 does not have auto-mdix, and I didn't have a crossover cable hanging around.  And then -- drumroll, please -- my derivative of Number 2 worked.  My long fiber runs are actually already buried in conduit.  To simulate them, I had a couple of short pigtails here in the lab.  My final test looks like this:
Router -copper- Switch1 - fiber - Switch2 -copper- PC
I'm not sure why I am not running at wirespeed on the LAN, but at this point I'll settle for consistent file transfers at ~800Mbps.  Most importantly, my laptop is also having no problem seeing the internet.
The setup is no different than what I thought I had put together last night, which I can say with confidence did not work.  So there's "more to the story," but the immediate reaction is that things are greatly improved.  It will probably be this weekend before I have time to spread the equipment and add the media converter and long fiber runs to the mix -- but as long as the associated cables are intact, I am anticipating positive results.
In the spirit of testing and pushing ahead while things are going well, I grabbed an old HP ProCurve 2810-48G switch from the closet and used it to simulate the end of the run beyond Link 4 in my original post.  I'm actually writing this reply from my laptop while connected there.  So right now it looks like this -- and it's working:
Router -copper- Cisco Switch1 -fiber- CiscoSwitch2 -copper- HP Switch -copper- PC
Again, sincerest thanks.  I will certainly post back when I experiment a bit more, and/or when I have it in "production" between the buildings.  I may have a couple of old Cisco wireless APs hiding out around here somewhere, so a future challenge will be trying to add them in the shop and the guest house, hopefully in standalone mode.  Stay tuned...!
Cheers, John
